what had gasket should I run with 84mm o ringed block?
Old Apr 17, 2012 | 07:20 AM
dantamparacer's Avatar
Default what had gasket should I run with 84mm o ringed block?
Ok I'm new to the whole o ring block thing for hondas but I know they run copper head gaskets on v8's with o rings. I'm trying to figure out what head gasket to order for my block since I have never seen a copper Honda head gasket. I have seen basic felpro head gaskets hold over 500wph but it was not o ringed. What gasket do you recommend?
Old Apr 17, 2012 | 07:28 AM
twkdCD595's Avatar
Default Re: what had gasket should I run with 84mm o ringed block?
Generally I have always heard you run a standard MLS type gasket (matching to your bore size obviously) with a copper oring'd block.
The copper headgasket was for when you run a stainless oring'd block and have a receiver groove cut in the head as well to match.
Old Apr 17, 2012 | 07:56 AM
dturbocivic's Avatar
call golden eagle and get one of their gaskets
Old Apr 17, 2012 | 01:05 PM
Divers's Avatar
x2
Old Apr 17, 2012 | 03:20 PM
hondaracing84's Avatar
I have an aebs copper o-ringed block bored to 84.5mm. I use a cometic head gasket and Im making over 650whp. Cometic has a lot of options as far as bore and thickness goes and seals very well. Golden eagle is a great option too. Golden eagle is just a stock oem honda gasket machined to your bore size.
Old Apr 17, 2012 | 07:22 PM
So any cometic or ge gasket in the correct bore size, any input on thickness for the cometic for high boost on a lsvtec at 9.3-1 ish. The head has been decked twice now I'm not exactly sure how much they shaved off either time. Car will be on ethanol and eventually on a small shot of nitrous if I'm not happy with the power it makes. I'm at altitude and only running a 6262, tuner is guessing it will sip making power around 600 due to the lack of oxygen
Old Apr 17, 2012 | 07:37 PM
My block was re-serfaced and so was the head, so we ran a thicker head gasket. I cannot remember exactly what size. I think it was a .040
.adam.
Jul 18, 2014 09:32 PM
hatchet_honda
May 16, 2009 02:28 PM
92HB_HB
Sep 12, 2005 09:28 PM
WREKONIZE V8 KLR
Apr 6, 2005 10:40 AM
hondafanatic1
Feb 19, 2004 05:35 AM
