If axle isn't the problem, then what is?
Old Apr 16, 2012 | 10:52 PM
frankiss123's Avatar
Default If axle isn't the problem, then what is?
after replacing my axcel should i be aware of fixing somthing els? like is something else wrong with my car that made that problem?
Old Apr 16, 2012 | 10:54 PM
doood's Avatar
been there done that
Default Re: axcel
why are you replacing the axle in the first place?
also, next time slow down and write coherent sentences. i had a hell of a time trying to decipher what the hell you were asking.
Old Apr 16, 2012 | 10:55 PM
jbpnoman's Avatar
Default Re: axcel
Considering we don't even know why you replaced the axle, we can't really answer that question.
Axles break. Boots tear. It happens.
Old Apr 16, 2012 | 11:04 PM
Default Re: axcel
its a 96 civic! and when i shift, and turn car makes a ticking or cracking sound in the front some were. someone told me it was my axcel! but im not sure, i dont know much about cars
Old Apr 16, 2012 | 11:13 PM
jbpnoman's Avatar
Default Re: axcel
So you haven't replaced the axle yet?
Just replace the thing. You've probably never done it before, and they do wear out on their own over time.
Old Apr 16, 2012 | 11:23 PM
Default Re: axcel
i just bough the car a month ago and just started to make that noise, so i stoped driving it! is it safe to drive it like that, or will somthing els get dammaged if i do? and no i havent replaced it yet
Old Apr 16, 2012 | 11:30 PM
jbpnoman's Avatar
Default Re: axcel
It isn't disastrous or anything, just replace it as soon as you can. Axles are fairly simple to replace.
Old Apr 16, 2012 | 11:33 PM
Default Re: axcel
allright, thank you
Old Apr 18, 2012 | 11:19 AM
91efsikevs's Avatar
Default Re: If axle isn't the problem, then what is?
Replace it before u break it and get stranded lol
Old Apr 26, 2012 | 11:34 PM
well the axel got replaced, and found out tie rod needs to be replaced, but that knocking or clicking sound is still ther when i shift or take off! you think thats the problem? (tie rod)????
Old Apr 27, 2012 | 02:42 AM
jbpnoman's Avatar
A knocking noise when you shift and take off sounds more like a completely shot motor mount hitting itself. Visually inspect all of your mounts, especially the torque mounts.
Old May 2, 2012 | 11:45 PM
big help about checking mounts, thank you so much. i had a private mechanic inspect the mounts, and turned out to be the rear motor mount that was completly off. i guess when the previouse owner did the engine swap he didnt put it on correctly so the enging was moving around everywere cause it was loose, luckly it didnt break. another question, "if there is an acura engine in the honda should it have diffrent motor mounts"???
RanCRX
Transmission & Drivetrain
Dec 28, 2009 03:03 PM
RanCRX
wu tang
14
Dec 17, 2007 09:23 AM
.M.
Sep 14, 2004 10:06 PM
Fooman
Jun 3, 2002 09:14 PM
