How to put a GSR cluster in a civic??
Old Oct 11, 2002 | 08:04 PM
HOND PWR's Avatar
Default How to put a GSR cluster in a civic??
I tried a search and all I could find was the wiring instructions.
I'm trying to put a 95 GSR gauge cluster in my 93 Civic hatchback. Does anyone
know how to do it? I saw some pics a while back, they used the gsr gauges with
the civic clear cover I think. Some please help as I'm now gauge less.
Old Oct 11, 2002 | 09:46 PM
TurboBumblBee's Avatar
Default Re: How to put a GSR cluster in a civic?? (HOND PWR)
sorry to be an ***.. but do a search.. i personally have helped out atleast 10 people do this to there civics.. i dont have the gsr cluster in the civic cover but i do have the gsr cluster in the civic dash, a guy on the board named acura_typer (i think) has done this conversion and sells the gsr cluster for about 200$ i think.. do a search and you can find a wiring diagram on how to wire the cluster, i cant post on HT now cause idont have on this computer..
Old Oct 11, 2002 | 09:55 PM
slowEJ6's Avatar
Default Re: How to put a GSR cluster in a civic?? (95CivicEX)
www.jdmfan.com/technical/ enjoy.
Old Oct 12, 2002 | 06:30 AM
Fuster_Cluck's Avatar
Default Re: How to put a GSR cluster in a civic?? (hybrid3do0rcx)
My question is does that same wiring apply to the 92-95, because the instructions on that site say for 96-00. I did a seach under "jdm cluster" and only found 10 threads with this one being the most on target for the install in a civic.
Thanks!
Old Oct 14, 2002 | 08:50 AM
Default Re: How to put a GSR cluster in a civic?? (LX98Civic)
no its not the same..
Old Oct 15, 2002 | 05:23 AM
Care to let us in on the differnces?
Thanks!
Old Oct 15, 2002 | 05:48 AM
Thanks!
follow this diagram that you could have found if you did a search and it will work correctly.. i have had it done since Feb and no problems at all...
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old Oct 15, 2002 | 08:01 PM
HOND PWR's Avatar
Started on my cluster today...GSR cluster with a civic cover. I cut thm both in half an plastic weld them together. A little bondo and it should all look factory.
Here's a pic of the car its going in.
Old Oct 15, 2002 | 08:42 PM
gleinz's Avatar
Good things those pics are so big, because I can't see a damn thing.
Old Oct 15, 2002 | 08:48 PM
HOND PWR's Avatar
Default Re: How to put a GSR cluster in a civic?? (gleinz)
Any bigger...I normally post a red X.
Old Oct 15, 2002 | 08:49 PM
acura_typer's Avatar
Banned
you are on the right track....
when your fingers are sore, and you dont want to sand any more, you'll realize you have a few more hours of sanding.
that reminds me, I have 1 more to complete. Just needs finishing touches, guess I need to get out and finish it now that my motor swap is done.
Old Oct 15, 2002 | 09:09 PM
Evs-One's Avatar
Solbros Owns Me
I like the pic- a slightly different angle and the light would have reflected much better. What color is that? Keep going on the gauges
Old Oct 15, 2002 | 09:30 PM
HOND PWR's Avatar
Default Re: How to put a GSR cluster in a civic?? (Emerica)
Acura_typer.... Thats the picture I was looking for. You sell them right? I tried to do a search but could not find the link, all I could find was some guy saying he helped 10 people? I guess he won't help 11. I will post pics when I'm done.
Emerica, I'm not much with a camera or a computer. The color is 99 Jeep Platinum
silver.
Old Oct 15, 2002 | 09:36 PM
Banned
yeah, I do them for people. I really don't make much on them, and I think if you make it turn out as good as the ones I do, you'll wish ya bought it instead.
If you have any quesitons, IM me. I have a few 'tricks'
Old Oct 24, 2002 | 06:25 PM
b18bomber's Avatar
hondpower, hey can you give me directions on how to do this? i just bought a new integra cluster that has the correct redline since i have an ls swap. i got a pretty good deal on the cluster and really want to know how to do this. i helped my brother do it in his, only the wiring which was easy, we couldn't get the cluster to fit in right though... what are you cutting? what are you gluing? what's your gameplan? those pics are really helpful..any info would be appreciated. thanks
Old Oct 24, 2002 | 06:34 PM
SlowB16's Avatar
Thanks!
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Each connector has a different number of pins that go into it. So what do you do about this?
Old Oct 24, 2002 | 06:43 PM
SlowB16's Avatar
Default Re: How to put a GSR cluster in a civic?? (SlowB16)
Id like to see what the final wiring looked like
Old Oct 24, 2002 | 07:39 PM
dwnthehatch's Avatar
Old Oct 24, 2002 | 09:39 PM
match the wires up to each other.. blue to blue, red to red, ect and wire them into the integra wire harness..
Old Oct 24, 2002 | 09:56 PM
SlowB16's Avatar
So what do you do with the extra wires? It seems like there would be extra....am I wrong. ANd if it as simple as matching color to color, then why is there a diagram. By the looks of the diagram, different colors do different things for the two clusters....
Old Oct 24, 2002 | 09:57 PM
SlowB16's Avatar
I am counting 22 for the civic plug, and 23 for the Integra plug
[Modified by SlowB16, 6:58 AM 10/25/2002]
Old Oct 24, 2002 | 11:22 PM
TakeMeOverThere's Avatar
it just takes time, i wired mine swap up in a hour, for the most part its just coloring matching.
[Modified by 95EG, 8:23 AM 10/25/2002]
Old Oct 24, 2002 | 11:35 PM
lucas569's Avatar
Default Re: How to put a GSR cluster in a civic?? (95EG)
you got any more pics of this setup? is that a canadian spec cluster mounted in a 5th gen civic?
Old Oct 26, 2002 | 09:49 AM
gleinz's Avatar
Default Re: How to put a GSR cluster in a civic?? (lucas569)
Did most of you guys do a GSR cluster swap just for the hell of it, or because you wanted that redline?
Old Oct 27, 2002 | 06:01 AM
Does anyone know what year GSR clusters will work in the EG h/b?
Are the clusters the exact same from 94-01? I need to go ahead and buy one for my 93 cx, so I would just like to know before buying.
Thanks!
