How to put a GSR cluster in a civic??
I tried a search and all I could find was the wiring instructions.
I'm trying to put a 95 GSR gauge cluster in my 93 Civic hatchback. Does anyone
know how to do it? I saw some pics a while back, they used the gsr gauges with
the civic clear cover I think. Some please help as I'm now gauge less.
Re: How to put a GSR cluster in a civic?? (HOND PWR)
Re: How to put a GSR cluster in a civic?? (hybrid3do0rcx)
www.jdmfan.com/technical/ enjoy.
Thanks!
Re: How to put a GSR cluster in a civic?? (LX98Civic)
no its not the same..
Care to let us in on the differnces?
Thanks!
Thanks!
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Started on my cluster today...GSR cluster with a civic cover. I cut thm both in half an plastic weld them together. A little bondo and it should all look factory.
Here's a pic of the car its going in.
you are on the right track....
when your fingers are sore, and you dont want to sand any more, you'll realize you have a few more hours of sanding.
that reminds me, I have 1 more to complete. Just needs finishing touches, guess I need to get out and finish it now that my motor swap is done.
Solbros Owns Me
Any bigger...I normally post a red X.
Re: How to put a GSR cluster in a civic?? (Emerica)
Acura_typer.... Thats the picture I was looking for. You sell them right? I tried to do a search but could not find the link, all I could find was some guy saying he helped 10 people? I guess he won't help 11. I will post pics when I'm done.
Emerica, I'm not much with a camera or a computer. The color is 99 Jeep Platinum
silver.
silver.
yeah, I do them for people. I really don't make much on them, and I think if you make it turn out as good as the ones I do, you'll wish ya bought it instead.
If you have any quesitons, IM me. I have a few 'tricks'
hondpower, hey can you give me directions on how to do this? i just bought a new integra cluster that has the correct redline since i have an ls swap. i got a pretty good deal on the cluster and really want to know how to do this. i helped my brother do it in his, only the wiring which was easy, we couldn't get the cluster to fit in right though... what are you cutting? what are you gluing? what's your gameplan? those pics are really helpful..any info would be appreciated. thanks
Re: How to put a GSR cluster in a civic?? (95CivicEX)
Thanks!
follow this diagram that you could have found if you did a search and it will work correctly.. i have had it done since Feb and no problems at all...
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Thanks!
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Re: How to put a GSR cluster in a civic?? (SlowB16)
Each connector has a different number of pins that go into it. So what do you do about this?
match the wires up to each other.. blue to blue, red to red, ect and wire them into the integra wire harness..
I am counting 22 for the civic plug, and 23 for the Integra plug
[Modified by SlowB16, 6:58 AM 10/25/2002]
it just takes time, i wired mine swap up in a hour, for the most part its just coloring matching.
[Modified by 95EG, 8:23 AM 10/25/2002]
Re: How to put a GSR cluster in a civic?? (95EG)
you got any more pics of this setup? is that a canadian spec cluster mounted in a 5th gen civic?
Does anyone know what year GSR clusters will work in the EG h/b?
Are the clusters the exact same from 94-01? I need to go ahead and buy one for my 93 cx, so I would just like to know before buying.
Thanks!
Thanks!
