Why does my subwoofer go crazy?
Old Oct 11, 2002 | 08:00 PM
shamoo's Avatar
Will you make something up for me please?
Default Why does my subwoofer go crazy?
Every once in a while, my subwoofer will make loud pulsing noises that will continue no matter what the volume is on the headunit. If I turn off the headunit, it will stop.
It will also stop when I move the wires going into the sub around. What can it be?
The noises are basically bass beats that happen about twice every second. It's very loud.
Old Oct 12, 2002 | 07:27 AM
gokuson's Avatar
Default Re: Why does my subwoofer go crazy? (shamoo)
maybe it's your amp. i had a alpine 2x50 and had it hooked up to 2 tens and it started acting up. found out that the rca terminals on the amp were loose. not only did i lost my amp, but i also blew my 2 10's.
check your amp...like borrow an amp from a friend and c if ur subs do the same thing
Old Oct 13, 2002 | 11:34 AM
shamoo's Avatar
Default Re: Why does my subwoofer go crazy? (gokuson)
It's a self powered subwoofer.
Old Oct 14, 2002 | 12:29 AM
philly-O's Avatar
try turning the gain down a little bit if it is turned up all the way. this usually helps
Old Oct 14, 2002 | 06:35 PM
shamoo's Avatar
Default Re: Why does my subwoofer go crazy? (peichie)
It just started doing this though. It sounds like there's actually something wrong, it's not like it just doesn't sound right, there is somthing defintely wrong.
Old Oct 14, 2002 | 07:17 PM
B18C1 for fun's Avatar
Check the ground on your amp.
Old Oct 15, 2002 | 10:09 AM
EndlEEsss's Avatar
HAHAHAHAH that happened to ME tooooo!!!!!!!!!!!
it sounds like a heart beat.
I forgot what i did to fix it, but i think one of the speaker wire on the sub was touching each other.
so crack open your sub, and make sure no speaker wires are touching.
Old Oct 18, 2002 | 05:38 PM
madwilliam's Avatar
I had the same issue - turned out to be a short in the signal line 'tween my amp and the subwoofer tho'.
turismo29
Audio / Security / Video
Mar 14, 2006 09:20 PM
Cory Matthews
22
Mar 6, 2006 02:13 PM
ringooo
17
Apr 6, 2004 09:21 PM
pr0jektdc2
Nov 11, 2002 09:54 PM
civicmark
12
Nov 10, 2002 11:25 PM
