took out my radio now car will only turn over,
Old Apr 15, 2012 | 12:10 PM
wanting an EF's Avatar
Default took out my radio now car will only turn over,
i took my radio out and it blew a fuse so i put a new one in and now the car wont even start ittl turn over but wont start i seen its missing the abs motor fuse would that do it? its an f22a 5 spd
Old Apr 15, 2012 | 01:18 PM
Hawkze_2.3's Avatar
Default Re: took out my radio now car will only turn over,
You probably also blew one of the ECU fuses...
Old Apr 15, 2012 | 01:22 PM
where are they located? i looked on the fuse box but didnt see any labled ecu
Old Apr 15, 2012 | 01:26 PM
Hawkze_2.3's Avatar
There are 2 fuse boxes to check (assuming you have a 4th gen), underhood and by the pedals..
Old Apr 15, 2012 | 01:32 PM
i prolly did it when i pulled a fuse to replace with the radio, so i mighta took the ecu fuse out by accident
Old Apr 15, 2012 | 10:09 PM
gstrudler's Avatar
At least on the 5g, the clock/radio fuse in the underhood fuse box is the ecu fuse as well.
Are you sure the fuse didn't blow again? What caused it to blow in the first place?
Old Apr 16, 2012 | 08:40 AM
thats what im trying to figure out. the po put like 4 ground wires in the radio area for some reason and every time i wire up my radio i blow a fuse, im tryina figure out the reason, and i think its an ecu fuse because ones missing
Old Apr 16, 2012 | 01:41 PM
found oil in my spark plug holes, pulled cylinder 1 plug fouled out and no electrode on the top. could that be the reason it wont start? new valve cover gasket and spark plug gaskets on the way for it but im wondering if thats the reason why it wont get any spark?
Old Apr 16, 2012 | 10:33 PM
gstrudler's Avatar
New spark plugs are cheap and you clearly have to replace it anyway, so you might as well and try again, although I doubt that's the problem. The car should be able to start on three plugs.
My suggestion if you haven't tried it already is to replace the radio fuse without any radio installed and try to start the car. If someone with a 4g could confirm that the radio fuse is the ECU fuse that would also be helpful.
Old Apr 17, 2012 | 12:22 PM
eshold's Avatar
Yes, the clock/radio fuse also powers the ECM.
fanta!
Dec 28, 2005 02:52 PM
NoLipRacen
Jan 29, 2003 05:16 PM
SIK IN DA HED
Oct 27, 2002 08:42 PM
2LoW4FaThOeS
Aug 4, 2002 10:40 PM
P()()RB@Y
Jun 7, 2002 12:41 AM
