Old Mar 25, 2015, 09:58 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Change battery, alarm blares non stop.
Old Apr 15, 2012 | 08:47 AM
Prophet1990's Avatar
Icon2 Change battery, alarm blares non stop.
Hello, pretty much sold my 94 accord and bought a new 97 one, love it its so clean and amazing but it had a bad battery so no problem just use the perfect red top from my garage I have sitting around, well I disconnected it no problem. put the new one in, ground first then i put the positive on and my alarm just BLARES.... key in the iginiton wont work hitting the key fob wont help so im pretty much clueless on what to do.... any ideas or thoughts would be of great help. I also tried taking the horn fuse out, which stoped the alarm but the car wouldnt start... so. im lost.
Old Apr 15, 2012 | 09:24 AM
drcSyntax's Avatar
Default Re: Change battery, alarm blares non stop.
Interesting...I'm assuming you've checked the manual for some kind of failsafe that triggers when complete power is lost; maybe there is a type of reset for it? I've read on other forums that people unplug the ECU and it resets the alarm. But that might not be a permanent fix.
Old Apr 15, 2012 | 09:32 AM
I might have to try that, this is starting to bother me. Brand new car but I cant drive it because I wanted to change the battery right when I got home... hard fail.. but I could unplug the ecu hook the battery up then reconnect it, that might work.
Old Apr 15, 2012 | 09:35 AM
joec44's Avatar
Is this a aftermkt. alarm? If so anything goes
you can try to hook up bat. with the key out of car if the alarm goes off try using the fob to reset it. or lock and unlock door or turn the key to on pos. Also you can a cable reset by removing the bat. and short the 2 cables together for 10 min. sorta like a reboot for a comp. good luck
Old Apr 15, 2012 | 10:32 AM
redbull-1's Avatar
See this link:
https://honda-tech.com/forums/showpo...14&postcount=2
Old Apr 15, 2012 | 07:49 PM
thanks! i got it working, enced up opening a remote and the model # was inside so got it to go smoothly! thanks all for the responses.
Knightrider03m
Jun 25, 2012 04:22 PM
1909ivanT
Nov 16, 2011 02:06 AM
barefootbilly
Audio / Security / Video
15
Jun 3, 2004 01:54 PM
Prod
Jan 13, 2004 01:29 PM
spdster
Dec 29, 2001 11:18 AM
