Head Gasket Test
Old Oct 11, 2002 | 06:42 PM
whagkangmakulet's Avatar
Default Head Gasket Test
Has anyone got ever got head gasket test? My car is not smoking anyhting, but I'm loosing a little water and my reservoir overflows?
Old Oct 11, 2002 | 10:35 PM
Louie B.'s Avatar
Default Re: Head Gasket Test (whagkangmakulet)
get a compression check to test your head gasket, but the problem doesn't sound like a blown head gasket to me. sounds more like a bad radiator cap.
[Modified by thumpu77, 11:36 PM 10/11/2002]
Old Oct 12, 2002 | 04:13 AM
JesseR's Avatar
Default If you want to test for a head gasket leak.....
when the car is cold, take the radiator cap off, then start the car....if the head gasket is fine, nothing should happen . But, if coolant bubbles out or shoots into the air, then you have a faulty head gasket.
Old Oct 12, 2002 | 04:55 AM
Chiovnidca's Avatar
Leakdown test.
Old Oct 14, 2002 | 05:51 AM
Default Re: If you want to test for a head gasket leak..... (JesseR)
I replaced the radiator cap and the thermostat already. I let my car Idle for about half an hour and the fan kicks in and temperature is normal. Once I'm driving and boosting about 7lbs, I parked my car to the side and notice that my reservoir is overflowing. If I let it overflow, my temp guage starts rising.
MLucas
Honda Civic (2001 - 2005)
10
Feb 7, 2018 11:52 AM
skUnK2jdm
Jan 30, 2007 05:36 AM
bigizsosexy
May 5, 2006 12:14 PM
00ITR #543
Aug 23, 2002 05:47 AM
BoostedD15B7
Jul 28, 2002 07:14 PM
