OBX 4-2-1 header
Does someone here have experience of OBX-R SS header in Integra Type R?
How are they for lowered Integra Type R?
Are they build exactly alike stock exhaust manifold ?
How is the ground clearance?
Thanks.
Thanks.
Cool Cool Island Breezes. BOY-EE
I had an OBX header that came wth my EM1. I swapped in a B18C-R and the header probably robbed power as compared to a stock ITR manifold. Garbage.
I have a RMF replica on my R right now. Feels like it makes a ton of midrange and top end. Feels like more power down low also. It was $250 shipped with a test pipe. I used the test pipe flanges and had a HFC made to avoid all the buzz and smell involved with a test pipe.
Including making a new cat, it was $350-400ish. Not bad. The JDM 98+ spec header is around $300-350, IIRC.
if the op wants to be cheap, buy my upper half, order a lower pipe from HMO and spend under 200 all said and done with new gaskets for an oem piece that works
or, spend 300-350 on a 98+ header which is slightly better and at least 10lbs lighter
From: Howcome we park on driveways, and drive on parkways?
I have the stock ITR exhaust. The header sounds about as raspy as any other header. Thin tube manifolds sound like a lot of ticking. The buzzing increased a tiny bit...but it sounds really good. Like a gritty noise. I like it a lot.
gavhowe
Oct 11, 2004 09:27 PM
