Door Panel
Old Oct 11, 2002 | 06:35 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Door Panel
i am removing the door panels from my 1994 civic. so far i have everything disassembled but the freaking thing you roll the windows down with. how do i get this out? i know there is a clip, but there is like no room to move around.
Old Oct 11, 2002 | 07:01 PM
PSU's Avatar
PSU
Default Re: Door Panel (DxHatchback)
anybody?
Old Oct 11, 2002 | 07:07 PM
PSU's Avatar
PSU
Default Re: Door Panel (JDM Sucks)
the part i'm referring to is the regulator handle which rolls the window up
Old Oct 11, 2002 | 07:23 PM
vladd's Avatar
Default Re: Door Panel (Mr Revels)
i had trouble with the same thing on my 97 hatch. i ended up breaking the handle off, which didn't matter since im putting on ex panels, but after i broke it off i saw there was a C clamp holding the handle to the metal stick thing. have a friend lift the handle with a flat screwdriver (don't do it too much or you'll break it like me) and shine a light, and get another flat screwdriver and pop the clamp out.
Old Oct 11, 2002 | 08:31 PM
mitchb's Avatar
Default Re: Door Panel (civicdxtyper)
Or you could spend 10 bucks or under and get you a trim tool specially made for that so that you can take it off in like 2 sec. literally.
Old Oct 11, 2002 | 08:47 PM
Simple's Avatar
Default Re: Door Panel (mitchb)
simply done really, take some really small tweezerz, and get a flashlight, look for the top of the thin little clip, it raps around the handle rod. its like a circle, but at the bottom it indents, then goes out like this
O <------- top
grab the top of it, the circle part, and pull
[Modified by Searching..., 5:50 AM 10/12/2002]
Old Oct 11, 2002 | 09:10 PM
civictypenos's Avatar
just use a flathead screwdriver,push the panel in about 1/2 inch,look for the clip,it will have two ends sticking out,push on one of the ends with the screwdriver and it will pop off,or just go buy the tool for it,its like $7 at any autoparts store.
Old Oct 11, 2002 | 09:26 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Door Panel (civictypenos)
Question for Tom, you dont have door panels, does water get inside the car when it rains or when washing the car?
Whats the purpose of the plastic sheet between the door panel and the metal?
Old Oct 12, 2002 | 07:09 PM
PSU's Avatar
PSU
Default Re: Door Panel (SpoonSportsEH2)
my uncle said thats to keep any water out
Old Oct 12, 2002 | 07:10 PM
PSU's Avatar
PSU
btw, thanks for the help guys. ill try and post pictures when the project is done!!
nihkiru
Jun 10, 2007 01:33 AM
calicojones
Feb 22, 2006 09:14 AM
businessmanph
Oct 30, 2005 10:45 PM
^LORTA^RACING
Mar 21, 2005 03:53 PM
xXx Justin xXx
Nov 28, 2004 12:14 PM
