Door Panel
Re: Door Panel (Mr Revels)
i had trouble with the same thing on my 97 hatch. i ended up breaking the handle off, which didn't matter since im putting on ex panels, but after i broke it off i saw there was a C clamp holding the handle to the metal stick thing. have a friend lift the handle with a flat screwdriver (don't do it too much or you'll break it like me) and shine a light, and get another flat screwdriver and pop the clamp out.
Re: Door Panel (civicdxtyper)
Or you could spend 10 bucks or under and get you a trim tool specially made for that so that you can take it off in like 2 sec. literally.
Re: Door Panel (mitchb)
simply done really, take some really small tweezerz, and get a flashlight, look for the top of the thin little clip, it raps around the handle rod. its like a circle, but at the bottom it indents, then goes out like this
O <------- top
grab the top of it, the circle part, and pull
[Modified by Searching..., 5:50 AM 10/12/2002]
O <------- top
just use a flathead screwdriver,push the panel in about 1/2 inch,look for the clip,it will have two ends sticking out,push on one of the ends with the screwdriver and it will pop off,or just go buy the tool for it,its like $7 at any autoparts store.
Don't Trust Anyone
Re: Door Panel (civictypenos)
Question for Tom, you dont have door panels, does water get inside the car when it rains or when washing the car?
Whats the purpose of the plastic sheet between the door panel and the metal?
nihkiru
06-10-2007 01:33 AM
