What is voltage for MAP sensor?
Old Apr 13, 2012 | 09:41 PM
Charlie Moua's Avatar
Default What is voltage for MAP sensor?
Q:
what should be the voltage of the wires going to the MAP sensor on the PLUG side?
what should be the voltage of the MAP wires leading into the ECU?
D17 & D19 slot
http://technet.ff-squad.com/wiring.obd1.htm
Old Apr 14, 2012 | 10:08 AM
Hidenplanvew's Avatar
Default Re: What is voltage for MAP sensor?
Im pretty sure its a 5v referance I cant remember off hand.
Old Apr 14, 2012 | 12:09 PM
dacrxguy's Avatar
pin 19 should be 5v
pin 17 is the signal
Old Apr 16, 2012 | 04:55 PM
Originally Posted by dacrxguy
pin 19 should be 5v
with the key ignII, should both d17 & d19 read 5v?
Old Apr 16, 2012 | 06:14 PM
another_aca's Avatar
they are voltage dividers. The ref to ground is 5v. The signal to ground voltage is variable, depending on absolute pressure. If the sensor is unhooked, there should be no reading on the signal wire. Voltage of ref to sig + sig to ground = refV.
Old Apr 18, 2012 | 07:57 PM
i just decided to run the 3 wires from map sensor to the ECU....
i figured there must of been a short somewhere.
NO more code 3 BUT car does have slight backfire at idel.... just not when you rev it.
Still running rich.
I'm going to try new ecu
carlos8
Engine Management and Tuning
Dec 26, 2013 01:15 PM
Veggie Man
Sep 25, 2012 02:49 PM
Charlie Moua
Apr 18, 2012 07:57 PM
Robs_B18c
Nov 4, 2009 08:39 AM
hondaeg8
Jun 22, 2005 03:03 PM
