F/S ls vtec turbo motor semi built complete
Old Apr 13, 2012 | 07:59 PM
egjdmcivichatch's Avatar
Default F/S ls vtec turbo motor semi built complete
Perfect for Street Car No Traction Issues!!!
Motor has less than 1k miles
Direct Plug in Play for 92-00 civic or Integra just needs Motor Mounts
No PartOut Unless I sell the Long Block FIRST!!
Motor Specs: LS V-tec
Block:B18A1(stock sleeves)81mm, Stock 89mm Crank,ARP Head Studs, JE Pistons 9:2:1 comp., ACL Race Bearings, Eagle Rods, ARP Rod Bolts
Head:1993 GS-R (B17) GS-R Cams, Skunk2 Springs and Titanium Retainers, Turbo Valves, New Valve Stem Seals
Golden Eagle V-tec/Turbo Oil Sandwich kit, Blox Intake Manifold(black)Power Coated, Rc 550cc injectors, AEM fuel rail, SARD Fuel Pressure Regulator B16 Black Super Clean Valve Cover, MSD Spark Plug Wires, Blox 70mm Throttle Body, Walbro 255lph Fuel Pump New
Turbo Kit:Turbonetics T3 Turbo (non-ball bearing) turbo needs Seals has Shaft Play, Tial 38mm Wastegate, Greddy Blow-Off Valve, 2 1/4 Intercooler Piping, New Coupler and clamps
Transmission:USDM 1994 GS-R Tranny w/ New Gears and Phantom LSD, Stage 2 ACT Clutch
New Duralast Autozone Axles
With Lifetime Warranty
Maintenance: New Head Gasket (OEM) Honda, New Timing Belt (OEM) Honda, New Water Pump (OEM)
New Oil Pump (OEM) Honda, NGK Racing 9 Spark Plugs
GS-R shiftlinkage
Dual Bend Short Shifter
ECU/Tune: Tuned by Bubba @ Do It Dyno
Made 278hp to the Wheels on 91 octane
8LB. Spring running of Wastegate
P28 w/ Hondata s100
Obd2 GS-R Distributor
Obd1 Rc injectors
Capable of Making 400hp+ w/ 14-16 psi of Boost w/ Retune and CTR or Skunk2 pro 1 Cams and Hondata 3 Bar map sensor
Call me or text me @ (714)851-5466 Tony
Trade for Only Welds or Exospeed rims with slicks & Skinnies 4x100 and money on top
Willing to Negociate if Offer is Reasonable or will start removing parts
Old Apr 14, 2012 | 09:25 PM
Default Re: F/S ls vtec turbo motor semi built complete
ttt
Old Apr 14, 2012 | 10:34 PM
aftermath1312's Avatar
Ttt
Old Apr 14, 2012 | 11:19 PM
EG9b20vtec's Avatar
Bump
Old Apr 14, 2012 | 11:27 PM
ej1serge's Avatar
Old Apr 16, 2012 | 05:45 PM
ttt
Old Apr 16, 2012 | 08:08 PM
Black-Ty [EG6]'s Avatar
bump for price range?
Old Apr 18, 2012 | 06:09 PM
ej1serge's Avatar
$4k
Old Apr 18, 2012 | 06:36 PM
yup
Old Apr 20, 2012 | 09:35 PM
ttt
Old May 18, 2012 | 03:33 PM
willing to part out long block hmu!
Old May 19, 2012 | 09:34 AM
sohcFerio's Avatar
ttt wish i could sell my motor for this
Old May 19, 2012 | 10:47 AM
thanx for the bump
Old May 19, 2012 | 10:49 AM
sohcFerio's Avatar
how flexible are you on the price??
Old May 19, 2012 | 11:58 AM
harms_is_back's Avatar
4 k not bad or the whole set up bump!!!!
Old May 19, 2012 | 04:57 PM
(714)851-5466 Tony
ask for tony
Old May 19, 2012 | 07:12 PM
sohcFerio's Avatar
txted you
Old May 19, 2012 | 09:16 PM
Peruviann83's Avatar
Originally Posted by egjdmcivichatch
thanx for the bump
Old May 21, 2012 | 11:34 PM
p3t3rxp4n's Avatar
how much for that sick *** vtec solenoid lol
Old May 22, 2012 | 08:44 AM
R.I.P 2000 Si's Avatar
bump
Old May 23, 2012 | 10:44 AM
sohcFerio's Avatar
ttt
Old May 23, 2012 | 10:49 AM
If motor sells will buy the turbo kit!
Old May 24, 2012 | 08:40 AM
ttt
jdmb16turbo
May 13, 2009 07:00 PM
murtnabila
Northern California (Sales)
Sep 2, 2006 09:31 PM
SIXTYdashONE
Dec 19, 2002 07:17 PM
