F/S ls vtec turbo motor semi built complete
Perfect for Street Car No Traction Issues!!!
Motor has less than 1k miles
Direct Plug in Play for 92-00 civic or Integra just needs Motor Mounts
No PartOut Unless I sell the Long Block FIRST!!
Motor Specs: LS V-tec
Block:B18A1(stock sleeves)81mm, Stock 89mm Crank,ARP Head Studs, JE Pistons 9:2:1 comp., ACL Race Bearings, Eagle Rods, ARP Rod Bolts
Head:1993 GS-R (B17) GS-R Cams, Skunk2 Springs and Titanium Retainers, Turbo Valves, New Valve Stem Seals
Golden Eagle V-tec/Turbo Oil Sandwich kit, Blox Intake Manifold(black)Power Coated, Rc 550cc injectors, AEM fuel rail, SARD Fuel Pressure Regulator B16 Black Super Clean Valve Cover, MSD Spark Plug Wires, Blox 70mm Throttle Body, Walbro 255lph Fuel Pump New
Turbo Kit:Turbonetics T3 Turbo (non-ball bearing) turbo needs Seals has Shaft Play, Tial 38mm Wastegate, Greddy Blow-Off Valve, 2 1/4 Intercooler Piping, New Coupler and clamps
Transmission:USDM 1994 GS-R Tranny w/ New Gears and Phantom LSD, Stage 2 ACT Clutch
New Duralast Autozone Axles
With Lifetime Warranty
Maintenance: New Head Gasket (OEM) Honda, New Timing Belt (OEM) Honda, New Water Pump (OEM)
New Oil Pump (OEM) Honda, NGK Racing 9 Spark Plugs
GS-R shiftlinkage
Dual Bend Short Shifter
ECU/Tune: Tuned by Bubba @ Do It Dyno
Made 278hp to the Wheels on 91 octane
8LB. Spring running of Wastegate
P28 w/ Hondata s100
Obd2 GS-R Distributor
Obd1 Rc injectors
Capable of Making 400hp+ w/ 14-16 psi of Boost w/ Retune and CTR or Skunk2 pro 1 Cams and Hondata 3 Bar map sensor
Call me or text me @ (714)851-5466 Tony
Trade for Only Welds or Exospeed rims with slicks & Skinnies 4x100 and money on top
Willing to Negociate if Offer is Reasonable or will start removing parts
GS-R shiftlinkage
P28 w/ Hondata s100
Obd1 Rc injectors
DDTECH
06-05-2011 12:42 PM
murtnabila
Northern California (Sales)
09-02-2006 09:31 PM
SIXTYdashONE
12-19-2002 07:17 PM
