turbo/internals help
I really wanna turbo my 00 prelude. Just wanna know what exact internals I should replace. Motor has 150k on it. I was reading earlier you can't put forged pistons in the aluminum block unless its the mahle. Or w.e. what June of pistons/connector rods should I get. Also not trying for stupid boost just want 10-12psi. But is that possible on a stock aluminum block?
PSI of boost is irrelevant because you can make the same power on low boost with a big turbo as with high boost in a little turbo. Most motors can handle a certain amount of horsepower. I'm fairly new to the prelude thing, I've had Civics, so I can't tell you what a Prelude engine can take.
After what I've read, most people suggest replacing the pistons because the ring lands will break. I figure if I'm spending the money for mahle gold pistons, rods, and may as well rebuild the head, I may as well sleeve the block and just be done with it and then I can run normal Mahle pistons I can get for cheaper and I know the block is stronger then.
I have a 93 prelude with a 95 h22 motor all stock. I have a garett gt 30 running 9 psi when I upped the boost to 12 psi my head lifted off of the block. At that time I thought I was running a safe tune and I only pit down 273 whp. how long your motor lasts is mostly based on how good your tune is. Now I have arp head studs but still stock motor.
