Need help with EGR vacuum control and solenoid diagnosis
Old Apr 11, 2012 | 11:13 AM
davidt1's Avatar
Default Need help with EGR vacuum control and solenoid diagnosis
Car: 94 Honda Accord
Problem: CEL code 12, EGR problem.
I took it out of the car. Using a power probe, I applied 12v to the connector. I didn't hear of feel anything moving or being activated. My question: what should happen when 12v is applied to it? Thank you for any help.
Picture of this part
Old Apr 11, 2012 | 06:07 PM
dglassmyer's Avatar
Default Re: Need help with EGR vacuum control and solenoid diagnosis
Here is the Helms troubleshooting flowchart for code 12 EGR.
I would have summarized but to be frank, didn't feel like reading all this
Old Apr 11, 2012 | 06:26 PM
jroxz44's Avatar
When u apply power to the silinoid u should get vaccume from yhe hose thats connected to the egr lift sensor ontop on the egr valve. Also a easier way to see if its working is pull the hose and put you finger on it while a friend revs the car. The egr only kicks in from 1800 rpm to about 3000rpm i think. I would suggest doing a whole egr system clean. Valve, passage and ports on intake manifold. Code 12 is lift sensor i beleive thou. Sometimes the hoses are just plugged up with a pieces or carbon or dirt.
D-Atk
Aug 21, 2019 03:35 PM
Smurf accord
May 30, 2013 11:00 PM
BoogerBurns
Classic Hondas
Sep 27, 2009 06:16 PM
double
Jul 30, 2004 04:24 PM
blackdelslo
Jul 8, 2004 09:45 PM
