Who can weld a stipped hole in alumminum?
Old Oct 11, 2002 | 04:27 PM
ragejed's Avatar
Default Who can weld a stipped hole in alumminum?
While fixing a stud that goes in my tranny for my tranny upper mount. I stripped the bolt hole in the tranny..I want to weld this hole shut, re drill and retap it. Will a welding shop do this? or should i just do it my way? Use http://www.alumaloy.net
Should I drop the tranny so I dont take chances of the propane torch blowin up the car? I also had sugestions that I can cover everything in the engine bay with a damn towel so It will decrease the risk of explosion. I rather do it this way then makin the hole bigger.
Old Oct 11, 2002 | 04:31 PM
mikeyz's Avatar
Default Re: Who can weld a stipped hole in alumminum? (ragejed)
machine shop should be able to do it for you
Old Oct 11, 2002 | 04:33 PM
EPGONZALEZ's Avatar
Default Re: Who can weld a stipped hole in alumminum? (mikeyz)
HELICOIL.. very easy and strong..
you just over size the hole...and thread in helicoil
Old Oct 11, 2002 | 04:35 PM
TREVER's Avatar
Default Re: Who can weld a stipped hole in alumminum? (EPGONZALEZ)
jb can do it
helicoils suck use timesert
Old Oct 11, 2002 | 04:41 PM
ragejed's Avatar
Default Re: Who can weld a stipped hole in alumminum? (TREVER)
Jb is not a bad idea. What exactly is it? Expoxy? Machine shop...where would i find one? Im from Fairfield, CT.
How safe is it to stick a propane torch in my engine bay?
Old Oct 11, 2002 | 06:07 PM
Bbasso's Avatar
"How safe is it to stick a propane torch in my engine bay?"
I really like this question.
Just be sure to heat up all the black metal lines that go near the intake manifold
Old Oct 11, 2002 | 06:36 PM
ITR764's Avatar
werd
Old Oct 11, 2002 | 06:42 PM
Dave-ROR's Avatar
bleh, that's not the only bolt/stud there.
[Modified by Dave-ROR, 10:43 PM 10/11/2002]
Old Oct 12, 2002 | 01:07 AM
ragejed's Avatar
Default Re: Who can weld a stipped hole in alumminum? (Dave-ROR)
umm
Old Oct 12, 2002 | 03:00 AM
ragejed's Avatar
So i read I can use Jb Weld to fill the hole, let it cure, drill and re-tap it? thats amazing, is it safe to do tho?
Old Oct 12, 2002 | 07:25 AM
EPGONZALEZ's Avatar
jb weld will not work..you also cannot retap jbweld....its just an epoxy
do not try to weld on your tranny!
keep that damn torch out of your engine bay...
i would pull the tranny out if you dont have alot of room to tap the hole out...
like i said..helicoil...thats what a machine shop is gonna do!
ive had a helicoil used on the headstud bolt threads with no problem...
tranny mount bolt should be no problem if you do it right
[Modified by EPGONZALEZ, 8:26 AM 10/12/2002]
Old Oct 12, 2002 | 07:28 AM
ragejed's Avatar
I read jb welds site tho, it says this.
"The physical properties of the adhesive allow you to drill, tap, machine andgrind the product after it has cured. And just like metal you can sand paperit, polish it and paint it."
Old Oct 12, 2002 | 07:31 AM
EPGONZALEZ's Avatar
allright then dude....give it a shot...
i also saw a commercial for OXYCLEAN saying it could take grape juice stains out of white carpet..
Old Oct 12, 2002 | 07:35 AM
ragejed's Avatar
Wow, your funny.
Old Oct 12, 2002 | 07:37 AM
EPGONZALEZ's Avatar
im trying to help you from doing something moronic...
no go JBweld your tranny Cooter
Old Oct 12, 2002 | 07:38 AM
ragejed's Avatar
are you talkin about using jb weld? or alumaloy?
Old Oct 12, 2002 | 07:58 AM
ragejed's Avatar
How About I just take out the bolt, clean the hole, put some jb weld on the bolt, and screw it back in the tranny?
Old Oct 12, 2002 | 08:25 AM
EPGONZALEZ's Avatar
then how do you plan on taking out the bolt when you need remove your transmission?
Old Oct 12, 2002 | 08:31 AM
ragejed's Avatar
Its just a stud, not a bolt. Double sided stud...
Ilovemyef9
Paint and Body
11
May 26, 2011 05:34 PM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
drshottest718
Welding / Fabrication
Nov 16, 2007 08:04 PM
civickiller
10
Aug 12, 2003 12:44 PM
ragejed
Oct 3, 2002 06:00 PM
