Engine Bay?
Old May 21, 2011 | 10:40 AM
Ilovemyef9's Avatar
Default Engine Bay?
I want to cover the hole in my bay but i dont have a welder, can i just cover them with the bondo or will the bondo go though..
Old May 21, 2011 | 11:58 AM
gorillafart's Avatar
Default Re: Engine Bay?
cover it with masking tape
Old May 21, 2011 | 01:16 PM
traderj's Avatar
I've heard you can use a circular piece of medal, larger then the hole, with some liquid metal. You put enough liquid metal on the piece and then stick it to the opposite side of your hole, letting it ooze out. Then you can grind it down and bondo that.
This process is used to patch up molding holes on the body. I've never done it myself though.
Old May 21, 2011 | 04:02 PM
Ilovemyef9's Avatar
Thanks ill try both
Old May 21, 2011 | 05:25 PM
229ek9's Avatar
Are you talkin about the extra holes?
Old May 22, 2011 | 05:54 AM
Ilovemyef9's Avatar
Im going to shave the engine bay..
Old May 22, 2011 | 09:59 AM
HighRevn's Avatar
Bondo will go through without welding it. You might be able to get away with using some sort of liquid metal with a washer underneath. Or you could look into panel bond adhesive which is basically chemical welding.
Old May 22, 2011 | 11:19 AM
Hawkze_2.3's Avatar
Panel bond adhesive
It is stronger than a weld if done right, and the process is almost the same as simply gluing things together and clamping them.
Old May 22, 2011 | 01:09 PM
Devon M's Avatar
Don't do it. It is more headache than it is worth. Use CF to cover the holes.
Old May 26, 2011 | 12:25 PM
Ilovemyef9's Avatar
Wat do u mean CF?
Old May 26, 2011 | 12:59 PM
Hawkze_2.3's Avatar
CF is carbon fiber...I don't see how that would be a better idea.
Old May 26, 2011 | 05:34 PM
ken9's Avatar
Use silicone..
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
SuM Honda
Nov 22, 2007 06:04 PM
namax
Jun 14, 2007 09:18 PM
melovesboost
Welding / Fabrication
16
Feb 17, 2007 09:23 PM
BB6Paul
Dec 7, 2005 08:26 AM
