What kind of flow rate of fuel do i need with 25 psi of boost?
Old Oct 11, 2002 | 04:20 PM
TurboB18C1's Avatar
Default What kind of flow rate of fuel do i need with 25 psi of boost?
Yea i am working on a secondary fuel system for my motor, and i have question what kind of injectors should i run in my car when i am pushing 25 psi??
Old Oct 11, 2002 | 05:53 PM
BudaKai's Avatar
Default Re: What kind of flow rate of fuel do i need with 25 psi of boost? (TurboB18C1)
Not to be a dick but your not ready for that much boost if you need to ask. Generally it depends on your set-up.
You know what your turbo's effeciency rate is that high.
How far in the revs you wanna run that much boost.
Which block you used and how it's built.
Whether your head has been built up or ported
I'd go with 720cc just so your not stressing the injector duty cycle, but like I said it all depends.
edit : Sorry your username says what block your running heh my bad
[Modified by tzsir, 8:54 PM 10/11/2002]
StrangerWitCandy
Feb 2, 2005 04:12 PM
electric_rex
Sep 24, 2004 06:21 AM
1sick4door
Dec 9, 2001 05:38 PM
LudeSi-93
Jul 22, 2001 10:57 AM
