Southern California Fresno & Below
good shop to install es master bushing kit, wheel bearings, ball joints...
Old Apr 10, 2012 | 05:31 PM
n0rmaL's Avatar
Default good shop to install es master bushing kit, wheel bearings, ball joints...
like the title says, im looking for a good shop to install new bushings, front wheel bearings and ball joints, i'll bring them all the control arms, hubs etc.. and the parts.
im located in the IE, but i'll drive to LA,OC or SD if the price is right.
Old Apr 11, 2012 | 07:48 AM
PilotOnDubs's Avatar
Default Re: good shop to install es master bushing kit, wheel bearings, ball joints...
what kind of car? full es master set? if so its a lot of pieces. suspension on the car or off? very time consuming and not an easy task.
Old Apr 11, 2012 | 10:34 AM
n0rmaL's Avatar
its a total of 20 bushings, 4 lower control arms, 4 upper control arms and 2 trailing arms, 2 front wheel bearings and all 8 ball joints upper and lower front and rear. 92 honda prelude
i have the parts off the car already just need the new parts installed
Old Apr 12, 2012 | 08:00 PM
Im trying to visualize the ones on the front wheel bearings, the rta's, and ball joints...
If you can pm me some pictures I can determine if I can tackle this project
Old Apr 16, 2012 | 05:29 PM
KINGVEM^^ED6's Avatar
Little late but steve^ is the man
Vouche alll day
Old Apr 16, 2012 | 06:47 PM
Thanx bud
Old Apr 18, 2012 | 05:44 AM
n0rmaL's Avatar
i found a place in temecula that did it for $200 out the door, they removed all the old bushings, bearings and ball joints and installed the new ones, not to bad imo seeing how all the other places i called wanted $300+
Old Apr 19, 2012 | 07:41 PM
Ah you got it done... I could have used the money
Old Apr 19, 2012 | 08:01 PM
Smitherz's Avatar
Most (ok all) shops around here on the Central Coast consider that tedious and busy work so they charge a lot more. It's pretty sad they try and bend people over for such simple work. Glad you got it done for a normal rate.
Old Apr 20, 2012 | 02:00 PM
eg2jr's Avatar
where was this done? shop name and number?
Old Apr 21, 2012 | 08:27 AM
I Wouldn't consider it bending people over for $300 or so for this type of job.
Its not that simple. It's very time consuming, especially if the parts are still on the vehicle. I did es bushings on the front of a Ef hatch, and it took nearly 4 hours. Different size bushings require specific size objects such as sockets to be used in order to press out the old bushings. Sometimes they dont fit well, and you have to just make it work. Not fun, not easy, and definitely not fast. That's why it does tend to be expensive.
Old Apr 23, 2012 | 07:31 AM
Smitherz's Avatar
Yeah I agree. If a car is dropped off and expects all the bushings to be replaced for cheap that isn't going to happen. n0rmal took off all the parts that needed bushings pressed in though so his cost should be low.
It also depends on if you find a tech that has worked on a lot of the same vehicle. I recently took a truck in to a shop to have an upper ball joint replaced. The mechanic said I should to check and see if the upper control arm wasn't much more money. I was like SERIOUSLY? Ball joint is $29 and I have it right now and you want me to go see if I can get the whole control arm so your lazy butt doesn't have to press it in for me? Oh that was a good laugh right in his face.
bigbpatel
Aug 3, 2012 05:04 AM
chrisw85
23
Apr 6, 2009 09:03 PM
OnlyHJC
Suspension & Brakes
Jan 8, 2007 02:36 PM
Ballade
Jul 29, 2005 10:34 PM
LoooseGSR
Mar 5, 2004 10:54 AM
