help with 4 bolt downpipe
Ok i have a turbo kit with a 4 bolt downpipe but i don't have the turbo. I am going to buy a turbo but before i do i want to make sure my 4 bolt downpipe will fit on any 4 bolt style turbo. Does ant one know if all 4 bolt patterns are the same?
no not all 4 bolts are the same. one may be 2.5" and another at 3" for the dp. just make sure whatever size your exhaust housing is matches your dp size. thats the only difference.
Ok, what's the smallest turbo with a 3in exhaust housing. I'm asking because is going on adx turbo just for gun until i get my b series done. Can i run a 3in downpipe on a 2.5 exhaust housing, because i don't want to buy a new dp.
There are 2 Garrett 4 bolts. The standard one is the T31 2.5" 4 bolt housing. Garrett, Precsion, Turbonetics, Comp Turbo, all use this, even for their 3" downpipes.
This is what your more than likely have
The only true 3" 4 bolt is the GT 3", which only comes on GT-R series ball-bearing turbochargers from Garrett
You do not have this: This is what W!d3b0dYr3X was referring to.
3" 4 bolt flange for GT-R series turbocharger only
Standard T3/T4 T31 2.5" 4 bolt flange
no one will be able to tell you the answer to that question without you telling us your power goals and the purpose of the car. if they attempt, then they dont know what the hell their talking about.
Don't promote the insanity that we turbo guys already deal with. When it dies, let's give him YOUR number so he can send it to YOU to fix it with your crazy little recommendations..
Hahahaha! I was trying to give him the answer he was looking for and most likely listen too! Unless he really wants something nicer and has the money to spend then it will be up to him.
W O T TWO
Dec 11, 2009 04:07 PM
