Transmission & Drivetrain Gearboxes, Differentials, Clutches
Flywheel weight?..
Old Apr 10, 2012 | 12:25 AM
gtm_maxwell's Avatar
Default Flywheel weight?..
Hi i m using a B20B vtec... my clutch ( OEM ) almost done... i m going to change a set of new fly wheel and new clutch... and i see many light weight flywheel in the market..
A) 4 to 4.2kgs
B) 3.8 to 4kgs
which one should i use? and what is the problem if use light weight flywheels?...
Please help...thx
Old Apr 10, 2012 | 12:33 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Flywheel weight?..
why do you wish to use a lighter flywheel?
Old Apr 15, 2012 | 10:25 PM
BrakeExpert's Avatar
Same reason everyone else wants one. Makes the engine sound rev-happy
Old Apr 16, 2012 | 12:10 AM
I was hopping that when i change the Light weight flywheel i can help the Rev?
Old Apr 16, 2012 | 06:36 AM
MonkeyMagic's Avatar
Depends.. doo you want something.that'll hold a decent amount of inertia so your woman could hop in and drive. Or do you want something that will dedicate every grain of rotational force to accelerating the car?
Of course from the masses given, there isn't much difference. Both are about half the mass of a stock flywheel. Might as well go for 3.8 as stock-like driveability will be thrown to the wind with either.
I'll add this: I daily a 12lb (5.448kg) and wish I had gone lighter now that I've gotten used to it. I'll also add that there are times in traffic I wish I had a millstone as a flywheel, or an automatic transmission.
FunForFree33
19
Mar 28, 2021 09:53 PM
LS94tegra
May 23, 2008 07:41 PM
funtak
Oct 25, 2007 08:47 PM
EJ8 GSR-T
Jan 30, 2006 10:34 AM
Mr. 1582
17
Sep 21, 2003 06:21 PM
