Transmission & Drivetrain Gearboxes, Differentials, Clutches
need help with clutch
Old Apr 10, 2012 | 12:03 AM
xdaaannyy's Avatar
Default need help with clutch
i've been trying to search online if anyone else had the same problem and i couldn't find any answers... heres the story as i was driving as i shifted to third gear it got stuck. so i pulled over opened the hood and noticed the clutch hydraulic hose popped so then i yanked it out of third gear to neutral to push the car to a area while i went to go purchase the hydraulic hose. after i installed the hose flushed the old clutch flid and put new in. i kept bleeding the slave cylinder as the clutch got stiffer and stiffer. when the car is off it goes into all the gears but when the car turns on it doesn't so i have no idea what the problem is. bad master cylinder? bad slave? or something flew out in the transmission... please help negative comments to your self thanks
Old Apr 10, 2012 | 12:31 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: need help with clutch
What year Ford?
$2 beer bet is you have a B series and the clutch spit a spring.
Give some more details.
Old Apr 10, 2012 | 10:32 AM
xdaaannyy's Avatar
my bad 2000 civic si b16a2
Old Apr 10, 2012 | 11:19 AM
MonkeyMagic's Avatar
sure you bled it well enough?
Old Apr 10, 2012 | 07:43 PM
xdaaannyy's Avatar
yeah i did
Old Apr 10, 2012 | 11:51 PM
Mista Bone's Avatar
D Tranny Guru
Replace clutch and you owe me a beer
B Series trannys, hard/impossible to get into gear while running but fine with engine off, 99% of the clutch the spring has popped out of the clutch disc. Average OEM disc only last 60k-70k before this happens.
an example....
Old Apr 10, 2012 | 11:58 PM
xdaaannyy's Avatar
thanks bone haha sigh takes awhile to get to huh?? maybe just take it to a shop -_- if you were by me i would!
Old Apr 11, 2012 | 12:07 AM
Mista Bone's Avatar
D Tranny Guru
I'm not a shop, never will be, I prefer to keep this as a hobby.
The clutch above, look at how much meat is left on it, barely worn IMHO.
BlkCivicFromTeamMNR.com
Aug 15, 2009 09:29 AM
Si93_22
Oct 29, 2007 08:59 AM
96WhiteOnBlack
Mar 26, 2007 07:15 AM
JFG Kevin
Jul 21, 2006 04:28 AM
mdj_ge
Dec 3, 2004 06:45 AM
