Hmotors H22A question
Old Apr 9, 2012 | 11:33 PM
h23bb1's Avatar
Default Hmotors H22A question
Ok so I'm getting ready to order the H22A complete change over/ with trans from hmotorsonline. And I was wondering what else I would need to swap it into my H23a1 w/auto trans? it comes with complete motor and trans. So what else would I need to buy or swap off my h23 to make this work?
Thanks guys.
Old Apr 9, 2012 | 11:36 PM
h23bb1's Avatar
Default Re: Hmotors H22A question
http://www.hmotorsonline.com/shop/sc...age&item=30017
Here's a link to the change over.
Old Apr 10, 2012 | 04:35 AM
spoolinlude's Avatar
I live under a rock
Pedal set, clutch components and lines, center console, shift linkage, shifter.
Old Apr 10, 2012 | 08:24 AM
h23bb1's Avatar
The swap I'm buying has linkage and shifter. But clutch components you mean like the lines and master cyl for the clutch?
Old Apr 10, 2012 | 08:28 AM
minilogoguy18's Avatar
Master cylinder, slave cylinder, lines, brake pedal, clutch pedal and a new clutch and flywheel would be a good idea.
Old Apr 10, 2012 | 11:17 AM
h23bb1's Avatar
I think it might come with the slave cyl to. And would the stock clutch and flywheel be ok to use for a few months cause I'm on a budget atm. And as for lines they are basically brake line right? So I should be able to buy and bend my own own lines then.
Thanks for the help so far. Ill hopfully be buying the swap in the next week or 2.
Old Apr 11, 2012 | 08:34 AM
h23bb1's Avatar
Bump. Still need info about if the clutch and flywheel are ok to use for a bit?
Old Apr 11, 2012 | 10:34 AM
cvcrcr99's Avatar
Yes, probably still good, but an OEM replacement isn't too expensive. Clutch/flywheel replacement is much easier with the motor out of the car. You should do it instead of having to go back and pull the trans out in the future.
Old Apr 11, 2012 | 12:22 PM
USDM as fuhh's Avatar
x2
Do it once, do it right. Always easier on you and your wallet in the long run.
Old Apr 11, 2012 | 04:11 PM
Canelidescope's Avatar
What you'll need:
Motor
hydraulic trans
pedals
Ecu
axles w/ half shaft
shifter cables
shifter assembly
stock motor mounts
alternator
starter
clutch
flywheel
intake manifold
exhaust manifold
fuel rail
injectors
distributor
engine harness
sensors
should be anywhere from 2,000-2,5000$
Old Apr 12, 2012 | 06:47 PM
h23bb1's Avatar
Ok, ill look into getting the OEM replacment. Thanks guys.
Old Apr 12, 2012 | 07:33 PM
Hidenplanvew's Avatar
You should do the clutch now, an exedy is only like 100 bucks for the kit and you can not use brake hard line from the master to the slave you need atleast a 6" section of rubber or steal brade line to flex while engine moves around .. You can run steal brade from the master to the slave but your looking at like 150 bucks for that
Old Apr 12, 2012 | 11:36 PM
horsepowerless's Avatar
people have already pretty much covered what you need. I did almost the same swap just about 6 months ago. lol. i went from an F22 auto to an H22a manual. one thing i find that helps keep costs down is searching junk yards. yes preludes are rare compared to other cars but they are also underestimated and people junk them for no apparent reason so you will find if you search.
also good luck with your swap.
Old Apr 13, 2012 | 04:56 PM
h23bb1's Avatar
Ok thanks again guys. Ill most likly buy a new clutch right away. The flywheel will most likley be on hold for a while.
slowassciv33
May 12, 2008 08:52 PM
Dr Wylee
Apr 20, 2007 04:33 PM
O RLY
Dec 22, 2006 07:40 PM
hmj88hb
Nov 18, 2006 07:57 AM
humtake
Jan 23, 2003 03:08 AM
