Climate Control lights do not work - '89 Civic
Old Apr 8, 2012 | 12:56 PM
777Brad's Avatar
Default Climate Control lights do not work - '89 Civic
In the years that I've owned it, the ligts have never worked. Since I'm replacing the radio, I had access to the back area of the climate control area.
Are there separate fuses for it? My fuse panel map does not seem to indicate a specific fuse for just the climate control area. Everything else on the car works.
Any ideas?
Thanks
Old Apr 8, 2012 | 12:58 PM
Pinja's Avatar
Drunk Wagon Pilot
Default Re: Climate Control lights do not work - '89 Civic
If I remember correctly there are very small bulbs used for illumination for the climate control. Try replacing those bulbs before anything.
Old Apr 8, 2012 | 01:01 PM
pimpwagon's Avatar
smack the side of the dash housing the controls a few times. every civic i've owned has lit back up this way. then i knew there were no blown fuses and chased down the bad connection in the dash. if this fuse was blown several other things would be out.
Old Apr 8, 2012 | 05:50 PM
777Brad's Avatar
Thanks, guys. I removed the radio & partially removed the climate control unit. I see wires going into it, but none of those appear to be lights. I couldn't easily remove the leads and see whether there were bulbs attached to the end of those wires.
I also smacked it several times, but unfortunately it did not work.
Any ideas on how to fix it?
Thanks again.
Old Apr 9, 2012 | 09:39 AM
spike32's Avatar
The bulbs may be in a small socket. The socket is removed 1/4 twist. You will see the wire loop from the climate control back into the climate control. 2 Bulbs. Located in the Upper Part. Maybe like this.
The Bulb # might be Part # 35505-692-003
Old Apr 9, 2012 | 03:56 PM
777Brad's Avatar
Hey that is fantastic! Thanks for that. Where can I get that?
Going into the back, I saw a wiring thing like #25 with a bunch of wires coming out of it.
Do you supppose that I'd have to take the front off & there would be lights at #1 & #7 ?
Old Apr 9, 2012 | 04:55 PM
spike32's Avatar
http://estore.honda.com/honda/parts/...n=&b=B++17&dl=
If 35505-692-003 is the correct part #, the bulb should cost around $2 + shipping. You can search google for this part #. You can walk into the dealership ask for the part #. Or, you can PM me, I have this bulb 2 @ $9 including shipping.
I don't know your specific vehicle. But from the photo it looks like the socket will give a 1/4 twist then come out, then you can remove the bulb from the socket. But it may be possible you need to remove the faceplate, but I doubt it. Someone else have this model can jump right in now !!
Old Apr 9, 2012 | 06:06 PM
djstevehawken's Avatar
Mine just went out on my 91 hatch. They were really easy to replace, you'll be able to figure it out when you do it. You don't have to remove the climate unit, the front pops off. I got my replacement bulbs at autozone.
Old Apr 9, 2012 | 06:09 PM
777Brad's Avatar
That's really good to know, because I wasn't seeing it from the back. I'll take a look at how to pop off the front.
Thanks for that info.
Old Apr 9, 2012 | 06:32 PM
jeanty's Avatar
yeah, you are correct.climate control lights .in winter .the bulbs in my home didn't work fully.because it's too cold .
Old Sep 25, 2016 | 12:26 PM
Jake Poole's Avatar
I apologize for resurrecting an old thread, but I saw there was no real solution here. So I have one.
The harness that goes to these lights is very simple, and I have an extra unit, so if I get some requests, I'll do a write up on changing the bulbs with some pics.
The climate control unit in an '89 Civic hatchback (not sure if it's the same as the 4door), has 2 tiny bulbs in it. I found the replacement bulbs at O'Reilly Auto Parts for $4.99, and they are the Sylvania 2721 bulbs. They're not hard to change, either.
hope this helps anyone looking. I looked FOREVER and finally found them myself.
delsolo95
Honda Civic (2006 - 2015)
Dec 17, 2012 05:33 PM
CincyCichlids
Jul 21, 2010 11:42 PM
Homotor
Jan 26, 2009 11:52 AM
EsQueue
Aug 3, 2003 07:44 AM
4drRacer
Aug 3, 2002 11:30 PM
