EF/DA Parts, Race/Track Car Parts, stock junk...
***EVERYTHING SOLD***
SPC Spherical Toe Links EF/DA/EG/DC $50 SOLD to Darussianone
OBD1 VTEC Distributor $50 SOLD to Darussianone
Energy Suspension Front Endlinks $5 SOLD to Darussianone
PR3 Upper Timing Belt Cover $FREE SOLD to Darussianone
DA Integra Car Cover $175 SOLD to DAve
DA Front Floormats $10 SOLD to Javier
0.5" Aluminum Top Hat Spacers $5 SOLD to BlackNinja
OEM Wheel Studs (8) $8 SOLD to BlackNinja
DA OEM Toolkit $5 SOLD to BlackNinja
Lugnuts, lugnuts, lugnuts $5 one set of OEM style SOLD to BlackNinja
DA Rear Upper Control Arms $FREE SOLD to BlackNinja
Denso OBD1 4-Wire Heated O2 Sensor $10 SOLD to Unified112
EF Outer Tie Rod Ends $10 SOLD to rollinmyDA
DA Front Upper Control Arms $5 SOLD to rollinmyDA
Hawk HP+ Rear Brake Pads $20 SOLD to Roderic
P72 Oil Pan $20 SOLD to Roderic
DA Muffler Delete $5 SOLD to Jeff on H-T
4040 Prop Valve $5 SOLD to Petar on H-T
Hubcentric Rings $5 SOLD to someone on H-T
Accusump Oil Accumulator w/ associated AN hoses and fittings SOLD to Andy Williams
92-93 Mudflaps $40 SOLD to DAJellie
DA Battery Tray $FREE SOLD to MugenED
B Series Thermostat Housing w/ ECT Switch $5 to MugenED
B17A Valvesprings & Retainers $FREE SOLD to MugenED
OEM B Series Cam Gears $FREE SOLD to MugenED
1992 Acura Integra Owners Manual $5 SOLD to MugenED
Remote Oil Filter & Oil Cooler Setup $80 SOLD to MugenED
Blox Intake Manifold w/ port matched TB, fuel rail... $250 SOLD to Mike from H-T
Left Side DA Fender Liner $TRASH
ECU Cover Plate (2) $TRASH
B Series Engine/Trans Stiffners $TRASH
2.5" T-Bolt Clamp $FREE
Lugnuts, lugnuts, lugnuts $TRASH
DA Alternator Bracket (lightweight non cast version) $TRASH
90-93 non-ABS integra. My GSR has a non ABS conversion on it and was using this valve but I bought a new one that was in better aesthetic condition to replace it.
Thanks!
I'll send you a text after I post this.
Thanks!
There was a leak which caused the paint to peel off on the bracket, but I think it was due to some of the brake lines only having a single flair instead of double. This prop valve was used for years on the car while my friend owned it and now a few years while I've owned it. During that time it hasn't seen much uses except for a bunch of track days.
