blown head gasket?
Old Apr 7, 2012 | 03:09 AM
ssmc12's Avatar
Default blown head gasket?
my ex has a 93 del sol with a 1.6,she has oil going into the radiator,its been like that for quite sometime,on wed she drove it and it was running like it should,but on thurs she went to go to work and it was pinging,sputtering,with alittle white smoke coming out the back...this is how it was described to me,I'll be looking at it today (saturday),i'm wondering if its a possible blown head gasket,and will a compression test show this.
thanks
Old Apr 7, 2012 | 03:58 AM
Tony S.'s Avatar
Default Re: blown head gasket?
Yes it does sound like the head gasket may be bad. A compression test may not show anything though unless it is completely blown. A leak down test is a better indicator of a HG problem.
Old Apr 7, 2012 | 04:00 AM
ssmc12's Avatar
oh lovely...thank you for your help,this car is going to be the death of me..lol
Old Apr 7, 2012 | 05:05 AM
94EG8's Avatar
Seagull Management
If there's oil in the coolant it's either a blown headgasket or a cracked head/block. You'll need to flush out all the old coolant (don't forget the heater core) and replace the headgasket, water pump, thermostat and rad cap (oil destroys rubber when you get it in a cooling system like that)
Old Apr 8, 2012 | 12:58 PM
ssmc12's Avatar
Well it turns out her issue was that she put in way too much oil,I drained the oil,replaced the plugs,the car now runs normal again,but I do see either a head gasket,or another motor in her future...thank you for everybody for your help...
Old Apr 8, 2012 | 01:19 PM
94EG8's Avatar
Seagull Management
Too much oil doesn't just mysteriously end up in the cooling system. Also if there's way too much oil in it half of it is probably coolant. Plan for a spun bearing in the near future.
dwashy21
Oct 25, 2013 02:44 PM
Red-Rag-B18
Aug 23, 2010 05:33 PM
88 EF Hatch
Jul 11, 2009 09:50 PM
NubImports
11
Mar 10, 2009 08:34 PM
djviet2000
23
Apr 29, 2008 09:36 PM
