thermostat question
Old Oct 11, 2002 | 12:47 PM
gsxr's Avatar
Default thermostat question
how often does the thermostat need to be replaced? every coolant change??
thanks
Old Oct 11, 2002 | 12:53 PM
MR. ARIZONA's Avatar
Default Re: thermostat question (gsxr)
I'm wondering the same ****. I just replaced my FAL SLIM FANS with some OEM fans and i had to pull the radiator out and drain it to get the fans out. Now my car overheats in traffic. Could it be the thermostat that needs to be changed?
Old Oct 13, 2002 | 01:45 PM
gsxr's Avatar
Default Re: thermostat question (QUICKTEG)
ttt
Old Oct 13, 2002 | 01:50 PM
The_Oz's Avatar
There are no set interval changes in regards to thermostats. It is like the alternator or your starter. You change it when it develops symptoms. However, since the thermostat and gasket are very cheap, and changing them can be quite messy, it is normally recommended to change it in every coolant flush/replacement.
Hope that answers your question.
Regards,
Oz
91akira
Apr 28, 2009 04:37 PM
M2B4
Apr 20, 2006 09:56 AM
whoa its len 2
Mar 22, 2005 12:27 PM
slickrc
Feb 6, 2004 10:16 AM
