Oil Leaking Between Head and Bottom Block
Old Apr 6, 2012 | 07:47 PM
frostykue's Avatar
Icon2 Oil Leaking Between Head and Bottom Block
So I recently rebuilt the HEAD on my 95 Integra GSR. After installing the HEAD onto the BOTTOM BLOCK, there was a LOW COMPRESSION in the 2nd Cylinder. Also, there is OIL leaking between the HEAD and BOTTOM BLOCK right above the Transmission. When trying to START the car, the OIL drips out all over the Transmission. Nothing was DONE to the BOTTOM BLOCK in the process of REBUILDING the HEAD. What steps would I need to do to FIX the COMPRESSION and OIL LEAK?
Old Apr 6, 2012 | 09:32 PM
ZombiePharoh's Avatar
Default Re: Oil Leaking Between Head and Bottom Block
did you INSTALL a HEAD gasket?
Old Apr 6, 2012 | 11:17 PM
B20ztek's Avatar
roflmao...if you don't know what the problem is, step away from the vehicle.
Its the headgasket,(or lack thereof) dude, come on.
Old Apr 6, 2012 | 11:46 PM
aftermath1312's Avatar
Did you get the head resurfaced?
If you didnt then that can be one of you problems.
Second problem might be you didnt torque thw head within specs
And the last thing i can think of is that you may need to get the block decked.
Old Apr 6, 2012 | 11:51 PM
mouab18c1's Avatar
It's rare that a block would need to be decked. Check all seals in that general region before taking it apart again.
Old Apr 7, 2012 | 07:03 AM
el crapitan's Avatar
did you follow procedure of any type of manual for this job?
assuming you did, what were the compression numbers of all 4 cylinders? it's possible you installed the head gasket upside down.
and this may be a silly question, but you did adjust the valve lash prior to installing the head, yes? because that needs to be done whenever you get a head back from the machine shop.
for the oil leak, brake clean off each suspected area one by one until you find it. places i'd look first:
-cam plug
-distributor
-valve cover seal
-vtec pressure switch
-vtec solenoid
so, if you followed the procedure, adjusted valve lash prior to installation, positive you'd installed the head gasket right side up, provide us the compression numbers. if you did everything correctly, you're going to need to blow some air into cylinder2 spark plug hole and see where it's leaking
Old Apr 8, 2012 | 09:13 AM
Rushintegra's Avatar
If I'm not mistaken they use stretch bolts on that head too so you might not be getting the right amount of torque on your head. But need to make sure the gasket is installed the correct way and I hope you had the head surfaced like these guys said
Old Apr 8, 2012 | 09:15 AM
Oh and if you didn't replace the head bolts would be a good idea to even if that isn't the actual problem. But it could be down the road. Better safe than sorry
Old Apr 8, 2012 | 09:22 AM
^^the head bolts aren't torque to yield. they're fine for reuse assuming they looked good
teggy!'s Avatar
It really sounds like he didnt use a head gasket at all. was the hear correctly rebuilt?
Old Apr 8, 2012 | 09:27 AM
my bet is upside down gasket.
mouab18c1's Avatar
Seriously? If you he didn't use a headgasket **** would leak everywhere.
Old Apr 8, 2012 | 09:34 AM
^^i know eh! i mean, we have to assume that much integrity at least
Old Apr 8, 2012 | 09:49 AM
teggy!'s Avatar
maybe he didnt use the correct head gasket. or didnt use the dowels when putting it in
Old Apr 8, 2012 | 06:10 PM
hondacl9's Avatar
did you use silicone in the corners and joints of the head
Old Apr 8, 2012 | 07:11 PM
slammedaccord91's Avatar
yea sounds like incorrect head gasket or torque issue - and head gaskets are installed completely dry!! make sure block is clean with no old gasket material or oil coolant etc...
shifts
Apr 5, 2007 07:26 AM
TurboASR
Mar 20, 2006 12:43 PM
Nisif
Nov 21, 2005 01:55 AM
sickerhatch
Mar 1, 2005 03:19 PM
servion
Feb 11, 2003 10:06 PM
