blue top 5g no spark
i got a h23a blue top in 00 sh prelude using td61u dizzy rywire bypass ckp/tdc sensor harness and still no spark, using oem ecu. my knock sensor is broken and unhooked will that keep and engine from sparking?
power for for the coil was switched with the tach wire on the td61u is that normal? and the firing order is different on the obd1 td61 over the stock h22a4 whatever it is.tdc on engine is cly #3 on the td61u dizzy. runs great
