head gasket questions
Old Apr 6, 2012 | 08:38 AM
vedocustoms128's Avatar
Default head gasket questions
i got 00 b16a2 and its stock internals and i wanted to change head gasket and use ARP head studs and put lil t3t4 and run like 8psi. but should i buy new OEM gasket from honda or some aftermarket is better. is COMETIC brand on ebay good. thanks guys
Old Apr 6, 2012 | 08:44 AM
jbpnoman's Avatar
Default Re: head gasket questions
Do compression and leak down tests first. Chances are, you don't need to rip it apart for turbo prep.
Old Apr 6, 2012 | 10:04 AM
I allready have tho hehe. I doing water pump n reast of gaskets n clean up underhood.
Old Apr 6, 2012 | 10:41 AM
jbpnoman's Avatar
You already have it ripped apart, but don't have the gasket yet?
Go OEM. Don't worry about all those aftermarket names.
Old Apr 6, 2012 | 01:49 PM
motegicivic's Avatar
Do not buy an Ebay headgasket.
OEM or at least a Fel Pro.
Old Apr 6, 2012 | 02:29 PM
Oem is always good but when i was getting arp studs they had some with head gasket n it was cometic brand n i didn't know if it was any good. Or better then oem
Old Apr 6, 2012 | 03:18 PM
beecee18's Avatar
Its fine to use cometic, just as long as you order it with your corresponding final bore size. And make sure to compare the thickness of it and compare to your existing one (oem honda)
I personally would just use a honda Oem gasket for your plans.
Old Apr 7, 2012 | 11:59 AM
Yea ill prob get oem honda. Thank you guys.
Old Apr 7, 2012 | 12:59 PM
DELshaneSOL's Avatar
yup use oem just did myn yesterday used
apr head studs also
oem headgasket
gates time belt
gmb water pump
and oem belt tensioner
Joeski99Si
Apr 23, 2009 05:24 AM
Joeski99Si
Apr 22, 2009 09:57 PM
tom4691
May 17, 2007 08:46 AM
jarven093
Feb 27, 2007 03:23 PM
01geeser
Oct 9, 2006 07:53 PM
