where to get sharp radius pipe bends?
Old Apr 6, 2012 | 05:02 AM
non-VTEC's Avatar
Default where to get sharp radius pipe bends?
hey guys
i'm looking for ultra sharp pipe bends in steel or stainless. specifically a 2.5" bend. does anyone know where i can get something like that? most mandrel pipe bends have a long radius...i need something short for a tight fitting down pipe. short of having someone do pie cuts i'm not sure if there is anything available?
something similar to this aluminium bend from atp turbo but obviously not aluminium: http://www.atpturbo.com/mm5/merchant...egory_Code=PPB
Old Apr 6, 2012 | 05:05 AM
EFjoe91's Avatar
Default Re: where to get sharp radius pipe bends?
check my thread 1 or 2 topics down. Let me know if thats what you looking for
Old Apr 6, 2012 | 05:11 AM
non-VTEC's Avatar
saw that...those U pipes look like normal bends...looking to see if there is anything available even sharper/shorter radius.....
Old Apr 6, 2012 | 05:19 AM
EFjoe91's Avatar
U bend is as tight as it gets- 180*, They are far from normal .These are sectioned out for what your looking for.
I purchase all that for the fact to cut apart and get "tight" radius
Segmenting these together creates the tight angles.
Old Apr 6, 2012 | 07:39 AM
non-VTEC's Avatar
I think I will fab up some pie cuts to get the angle I need...
Old Apr 6, 2012 | 08:01 AM
EFjoe91's Avatar
Every time I think about tight bends I think about this build I saw.
I am trying to accomplish something simmilar what you see here.
Is this what you consider Pie cuts?
Old Apr 6, 2012 | 08:14 AM
non-VTEC's Avatar
Yes....those are pic cuts but it seems like a huge waste of time since none of those bends are really that tight where they couldn't use normal bends.
Old Apr 6, 2012 | 08:56 AM
PRLdrag240's Avatar
www.fabspeed.com
they do 1D full 180 degree bends
Old Apr 6, 2012 | 10:08 AM
laydoutjimmy's Avatar
Definitelly not a waste of time. That entire build is all titanium so that was bascially the only option next to paying prob $100+ dollars per bend, thats if you can even find them
Old Apr 6, 2012 | 10:09 AM
non-VTEC's Avatar
ahh cool....that would explain it....my bad....
Old Apr 6, 2012 | 10:21 AM
CRMB's Avatar
OG Fabricator
1*D radius bends flow like crap, don't use them if you don't have to. I would equate them similiar in flow to a crush bend.
Old Apr 6, 2012 | 11:53 AM
Golfball's Avatar
man if you can find titanium bends for 100 bucks you let me know cause you can easily spend 100 bucks a bend just on SS...
Old Apr 6, 2012 | 08:37 PM
SovXietday's Avatar
Have you looked into the donuts?
http://gelanz.com/xt500/oil%20tank/Donuts.pdf
Old Apr 7, 2012 | 01:30 AM
Boosted_B_Series's Avatar
Those donuts are pretty sweet, and expensive..
Old Apr 7, 2012 | 03:58 AM
non-VTEC's Avatar
that might just work out perfectly.....where to order from?
Old Apr 7, 2012 | 08:47 AM
non-VTEC's Avatar
hmm....just came across this that also might work out really well from SPA turbo USA:
http://www.designengineering.com/cat...-cast-downpipe
http://www.designengineering.com/fil...spa/090918.pdf
now i just gotta find out the dimensions of the turbo outlet of a garett t3/t04 57-trim stg3 .63a/r to see if it will line up.....
Old Apr 7, 2012 | 09:50 AM
forthrills's Avatar
SPD donuts in Steel or Stainless
Old Apr 7, 2012 | 06:42 PM
SovXietday's Avatar
Considering you usually only need one tight bend on a project, they definitely are worth the money.
non-VTEC, dunno where to get them from, but I've held a few in my hands so they're def available!
Old Apr 22, 2012 | 07:39 AM
dturbocivic's Avatar
chassis shop . com sells donuts
Old Apr 23, 2012 | 12:17 AM
klattr1's Avatar
Woolf Aircraft has bends where the CLR is the same as the diameter.
1QwIkEf
Welding / Fabrication
Dec 20, 2011 04:31 AM
jbrick28
Mar 17, 2007 08:00 PM
r0yal
Apr 19, 2006 07:03 PM
CRX_GUY_123
May 26, 2004 11:26 AM
Etylorcen
Mar 20, 2002 11:20 AM
