Quick question...?
I'd like to know, if I can mate a 2000 Ls, cylinder head with 94 Ls Block. The reason I ask, is cause I have a 94 Integra Ls with a burnt valve and one of the Exhaust studs is broken. And also, I have a 2000 Integra Ls fully assembled that I'd like to use, but I'm not too sure if it'll work. If it does, which head gasket and timing belt, should I use?
Thanks.
Thanks.
So just to make sure, can I use the Distributor from my 94 Ls on the 2000 Ls Cam? The only reason I'm questioning this is because, Acura/ Honda has two different part numbers for the head gasket and timing belt and all of the top end components.
Will the intake manifold from 94 really work? The 2000 Head have a PVC valve on the cover. Only thing I can think of, is plugging the whole on the valve cover or using the obd1 valve cover. Sounds correct?
You will have to get a OBD1-OBD2 conversion harness for this to work, unless u want to cut an splice. Don't do that, just spend the $20 or so dollars and plug and play
moncrease
Mar 11, 2008 05:23 PM
