Quick question...?
Old Apr 5, 2012 | 02:02 PM
nemesis25's Avatar
Default Quick question...?
I'd like to know, if I can mate a 2000 Ls, cylinder head with 94 Ls Block. The reason I ask, is cause I have a 94 Integra Ls with a burnt valve and one of the Exhaust studs is broken. And also, I have a 2000 Integra Ls fully assembled that I'd like to use, but I'm not too sure if it'll work. If it does, which head gasket and timing belt, should I use?
Thanks.
Old Apr 5, 2012 | 02:06 PM
DELshaneSOL's Avatar
Default Re: Quick question...?
The head itself is the same, the only differences between the 2 would be the distributor, and injectors, 94 is obd1 and 00 is obd2.
Old Apr 5, 2012 | 02:51 PM
nemesis25's Avatar
So just to make sure, can I use the Distributor from my 94 Ls on the 2000 Ls Cam? The only reason I'm questioning this is because, Acura/ Honda has two different part numbers for the head gasket and timing belt and all of the top end components.
Old Apr 6, 2012 | 01:13 PM
nemesis25's Avatar
Anyone?
Old Apr 6, 2012 | 02:06 PM
DirtyDA9's Avatar
Just swap over the distributor and intake manifold from your 94 onto the '00 and you will be good to go
Old Apr 6, 2012 | 03:25 PM
WhiteNeko's Avatar
Will the intake manifold from 94 really work? The 2000 Head have a PVC valve on the cover. Only thing I can think of, is plugging the whole on the valve cover or using the obd1 valve cover. Sounds correct?
Old Apr 6, 2012 | 04:23 PM
DirtyDA9's Avatar
You can swap over the valve cover then, but I would just do a catch can setup.
Old Apr 6, 2012 | 04:35 PM
nemesis25's Avatar
How about the head gasket and timing belt? Which ones should I use?
Old Apr 6, 2012 | 05:43 PM
dlo253's Avatar
They are all the same for LS no matter what year.....
Old Apr 6, 2012 | 09:37 PM
1ls/vtec's Avatar
You will have to get a OBD1-OBD2 conversion harness for this to work, unless u want to cut an splice. Don't do that, just spend the $20 or so dollars and plug and play
ahs2m2
May 13, 2008 08:35 PM
moncrease
Mar 11, 2008 05:23 PM
Big_S
Sep 13, 2004 06:15 PM
IgniteTeg
May 7, 2004 06:24 AM
one11racing
Jun 10, 2003 02:32 PM
