d16z6 aftermarke valvesprings with oem retainers?
Old Apr 4, 2012 | 01:14 PM
joppe's Avatar
Default d16z6 aftermarke valvesprings with oem retainers?
try to run about 400whp with bisi 2.4 cam or something. I was thinking to run with OEM retainers, is that bad idea?
http://www.ebay.com/itm/HONDA-CIVIC-...ht_3196wt_1396
http://bisimoto.com/store/index.php?...roducts_id=220
What is proven for good to 8.5-9krpm?
Old Apr 4, 2012 | 01:38 PM
kbouchard1092's Avatar
Default Re: d16z6 aftermarke valvesprings with oem retainers?
Def bad idea
Old Apr 4, 2012 | 04:06 PM
NonovUrbizniz's Avatar
Loved
You can use stock retainers you just can't expect to rev it as high safely. And it can depend on the design of the spring or the material/design of the stock retainer.
The titanium retainers are more for reduced weight... When there is more mass in the spring/retainer they do not respond as fast at high rpm and you can get valve float.
For a certain answer you should always contact the manufacturer directly.
Old Apr 4, 2012 | 07:05 PM
FarmYard's Avatar
me and danz both use oem retainers and aftermarket valve springs with the newer (z6 and y series) heads. the oem retainers are only slightly heavier than titanium and very reliable. 3 years of 10 second passes and no issues. 9000rpm+
Old Apr 4, 2012 | 07:47 PM
joppe's Avatar
What springs you have?
Old Apr 5, 2012 | 06:22 AM
scottdh20's Avatar
im also running the delta 272-2 (bisi 2.4 equivilent except it wont break in half), crower springs, stock retainers/keepers, 8500 rpms with no problems....
22psi out of an hx35 unknown power
spoolinvtec54
Mar 17, 2011 12:46 PM
WarpFactorVIII
Aug 20, 2007 06:08 PM
DelSolDon
Oct 5, 2005 04:58 PM
