Twin 044 - 8 Injectors - E85
which will max out first? turbo or fuel system?
4 ID2000 + 4 FIC 1600 + Twin 044 + E85 / S372 A/R 1.25 on a Built 2L motor.
Hey I'm running a b16 84.5mm s400 67.mm 1.25 housing on a full race top mount & itr cams.. Will 1600cc injectors & 2 Bosch 044 pumps be enough to run that turbo without worrying bout running out of fuel?
This is general math, dont quote me exactly...
On twin 044s, you'll be able to make around 855-950hp on E85 before the pumps will run out of breath, give or take...this is about 800-850 lbs/hr of fuel flow. Your 1600cc will only flow around 640 lbs/hr at a 45psi base so they will be out of fuel at around 700hp give or take.
Fuel setups are always easy to upgrade...
If the pump doesnt have enough supply, just get a bigger pump.
Like Tony said, the limiting factory might be the voltage...so simply adding a Boost-A-Pump might get you over that edge too
I ran 8 ID 1000cc's with 2 044's (one pump feed one rail) with 85 psi base pressure on the integra last season. Went 167mph at close to 2600 lbs at mid 70% IDC. I was running ignite red, and it was cut down with some 100 octane to meet "e85" on the tester.
1600s and Q16 you would get close to your goal....
By a barrel of E98 or some form of Race E85, Ignite, Rocket....etc
I've read that his eliminates the use of an alternator right?
Won't other electronics be affected running a 16v battery like gauges, ecu etc.?
What if we run this batt and still retain the oem alternator to eliminate the use of a
16v battery charger is it possible?
