1994 honda accord lx tachometer wire location?
Old Apr 3, 2012 | 02:58 PM
DannyBoy310's Avatar
Default 1994 honda accord lx tachometer wire location?
does anyone know where the tachometer wire is located in a 1994 honda accord lx? if possible, can you include a picture. I have tried searching but nothing comes up.
Old Apr 3, 2012 | 04:34 PM
dglassmyer's Avatar
Default Re: 1994 honda accord lx tachometer wire location?
Are you talking about where the tach wire gets its signal from the distributor/ICM, or the test hook up location.
Either way they're both blue wires.
Ill see if I can dig it up for ya.
Here is the actual location the tach gets its signal from on the ICM, which is inside the distributor, and the appropriate wiring schematic.
Again, the blue wire is what you're looking for.
Old Apr 3, 2012 | 06:10 PM
Im just wanna make sure this is the blue wire that sends the signal to the tachometer before splicing into a wire that is not the correct one.
The wire is the all blue one right in the center of the picture correct?
Old Apr 3, 2012 | 06:33 PM
dglassmyer's Avatar
Yes, the tachometer signal wire is on the 2P connector with the YEL/BLK wire.
Leave the 8P alone as it does have BLU/GRN and BLU/YEL wires on it but these are for your CKP sensor.
Why are you splicing into the tach wire?
The test lead location would be a much more suitable area to run an accessory off of as it is already "spliced" off the main line that runs to your tachometer.
Old Apr 3, 2012 | 06:39 PM
I was giving a shift light and im trying to install it but was having trouble trying to get the tach signal wire. where is the test lead located?
Old Apr 3, 2012 | 06:42 PM
dglassmyer's Avatar
Look for a rubber covered hookup at the end of one wire all by itself.
It kind of looks like an inline fuse with the cover on.
It is located near the passenger side strut tower near the main engine harness connections.
Old Apr 3, 2012 | 06:57 PM
ok ill try and find it right now.. thanks for helping me out man
Old Apr 3, 2012 | 07:01 PM
ok i found it, would it be ok to splice into this wire? just asking because i dont seem to have a connector that would fit it.
Old Apr 3, 2012 | 07:09 PM
dglassmyer's Avatar
No problem, yes if you are splicing into it the test lead location would be the better of the two points to do so.
Old Apr 3, 2012 | 07:17 PM
ok thanks for sticking with me man..
Kingpho
Apr 1, 2012 05:48 AM
jareddx
Mar 4, 2010 06:59 AM
Gonzo_SiR
Oct 29, 2003 10:12 PM
arjusmc
Jul 2, 2003 03:57 AM
projectcrx
May 15, 2002 10:36 PM
