1in or 2in exhaust wrap
Old Apr 2, 2012 | 10:07 PM
93lsv_turbo's Avatar
Default 1in or 2in exhaust wrap
i have a log manifold that i want to wrap. i wanted to know it from ppl that have done it before if they used 1 in or 2 in wide wrap and my a pic of the finished product?
thanks
Old Apr 3, 2012 | 06:37 AM
scottdh20's Avatar
Default Re: 1in or 2in exhaust wrap
i would have to say 1"
i've wraped 3 or 4 downpipes with 2" getting it around those bends isnt hard but i wouldnt want to attemp anything with a tighter bend radius.... i plan on 1" if my ramhorn
and the trick to a nice tight wrap is to soak it in warm water first...it will slightly loosen up the fibers while wet and it will tighten back up as it drys
Old Apr 3, 2012 | 07:07 AM
i was thinking 1in but i wanted to ask before i bought. did you use the insulating spray with it on the downpipes?
Old Apr 3, 2012 | 09:00 AM
nealnanoHX's Avatar
1 inch wrap would work best. Good luck trying to wrap it.
Old Apr 3, 2012 | 10:53 AM
kbouchard1092's Avatar
While this topic is up , what is the best way to clamp the wrap @ manifold...is there better way then using ugly *** hose clamps? maybe some sort of wire ties that doesnt look as bad.
Also soaking in warm water prior to adding the wrap seems like good logic
Old Apr 3, 2012 | 01:15 PM
rs250nut's Avatar
This is the way forward, secure it with lock wire.
Old Apr 3, 2012 | 03:57 PM
MRGRIM's Avatar
R.I.P. Mark
have a look at these ties Ive used them with great sucess
http://www.ebay.com.au/itm/10-8-Stai...item19cc4cc9ba
Old Apr 3, 2012 | 05:50 PM
jv88_dc2's Avatar
Wear gloves and make sure your skin doesn't make any contact with the wrap. That fiberglass stuff is no joke and will irritate the **** out of your skin. Just a heads up! I had to learn this the hard way!
Old Apr 3, 2012 | 08:23 PM
I EFFING HATE LOCKWIRE (did it in all caps that way you know how serious i am about not liking lockwire)
the good thing about it is you could probably wrap over top of it and never see it!
FRKWOO
Jul 24, 2009 11:17 AM
ejLday
Detailing
Mar 25, 2009 08:54 PM
GSP
Feb 7, 2007 06:50 PM
1SlowSi
Mar 11, 2005 05:56 AM
Spade
Jun 21, 2002 09:54 AM
