91 EF overheating...fan wont come on
Old Oct 11, 2002 | 08:47 AM
RCLGSR's Avatar
Default 91 EF overheating...fan wont come on
my friend's '91 DX hatchback (150k miles) is overheating. the fan wont come on, and the coolant in the reservoir started boiling.
any idea what the problem could be? relay or fuse maybe?
thx in advance!
Old Oct 11, 2002 | 09:00 AM
4gvtec's Avatar
Default Re: 91 EF overheating...fan wont come on (RCLGSR)
check the fuse
unplug and run the fan direct to the battery to eliminate the fan motor
then you have the thermo switch,thats what turns the fan on when the coolant reaches temp
and the realy but its usaly the thermo switch
Old Oct 11, 2002 | 10:17 AM
keithv's Avatar
Default Re: 91 EF overheating...fan wont come on (4gvtec)
i went through 3 relays before i got one to work for my cooling fan.
1. check the fuse.
2. then the fan itself.
3. then the relay.
the relay is easy to test as you just connect the 2 wires coming off the thermo switch together. once that is done, put your ignition to the II position and the fan should kick on.
if the fan works for all 3 of those steps and still doesn't come on, then the thermo switch is bad.
[Modified by breaka_1_9, 2:17 PM 10/11/2002]
Old Oct 11, 2002 | 11:36 AM
pelotudo's Avatar
Default Re: 91 EF overheating...fan wont come on (breaka_1_9)
<--Has his fan hooked up directly to the ignition switch. When the car is on..so is the fan. Haven't overheated once; plus, my turbo inlet piping is constantly supplied with a nice flow of air.
jB
apexi_rsx
Jul 19, 2013 07:43 PM
xTomei
10
Jun 7, 2010 06:02 PM
Black Paper Diary
May 19, 2006 03:16 PM
turbo*s2k
Oct 28, 2003 08:05 AM
turbo*s2k
Oct 27, 2003 06:33 PM
