Disk swap.. what suspension to use?
Old Oct 11, 2002 | 08:38 AM
Chris's Avatar
Default Disk swap.. what suspension to use?
I have a 91 Civic STD.
I am reading from searches that I will need 90-91 EX fronts (for my B16 axles to fit) and to do the rears, Ill need 90-91 Integra rear disks, LCA (including trailing arm, but keep stock compensator arm)
If I want to do suspension, do I order shocks and springs for an Integra? or Civic? How about Sway bars (if I used 90-91 integra LCA)
PLEASE CORRECT ANYTHING I MIGHT BE WRONG ON!!
Thanks.
Old Oct 11, 2002 | 08:46 AM
EP3_05's Avatar
Default Re: Disk swap.. what suspension to use? (Chris)
You can use dx/si hubs up front if you can't find the bigger ex hubs. The ex uses larger brakes and therefore they are sought after.
Old Oct 11, 2002 | 02:56 PM
Chris's Avatar
Default Re: Disk swap.. what suspension to use? (91civic)
any other insight?
Old Oct 11, 2002 | 03:37 PM
APEX i GSR's Avatar
I did the same sort of swap on my wifes EF Std.
We used CRX Si rear trailing arms & used a Civic Si suspension
When i installed everything i used Integra emergency brake cables & used new rotors & pads
We used the front spindles off of the same CRX Si here are some pics
Old Oct 11, 2002 | 03:38 PM
APEX i GSR's Avatar
i heard if you use the trailing arms from an Integra it will throw your alignment off
Old Oct 11, 2002 | 04:08 PM
my_slow_civic's Avatar
http://fourthgenhatch.com/reardiscswap.html
Old Oct 11, 2002 | 04:09 PM
Losrocket_'s Avatar
Default Re: Disk swap.. what suspension to use? (APEX i GSR)
Im using the rear disks off of a del sol for my disk swap. Heres the the thing, theyre coming off of my friends '97 CX and hes using a 99-00 Si E-brake cable. Will the Si E-brake cable be long enough for my sedan? Im almost positive it will I was just wondering if anybody else had any experience with this swap.
Thanks!
Old Oct 13, 2002 | 05:12 PM
Chris's Avatar
Default Re: Disk swap.. what suspension to use? (kbslacker)
Thanks!
Old Oct 16, 2002 | 12:35 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Disk swap.. what suspension to use? (Losrockeeto)
Thanks!
i would like to know too...TTT
Old Oct 16, 2002 | 04:19 AM
keithv's Avatar
Default Re: Disk swap.. what suspension to use? (Ham'ed Hatch)
one more site out there...
http://tjshondas.20m.com/rrdisc.htm
tj has always had some really good info, so i highly trust this source.
civicSiR1.6
10
Jan 27, 2010 07:11 AM
length
Aug 20, 2004 01:52 PM
89-ef
Feb 12, 2004 03:04 PM
CB_ejcoupe
Nov 14, 2003 03:23 PM
turbod16y7vtec
Apr 20, 2003 08:25 PM
