ls turbo code 35? need help please
ls turbo tuned on chrome. 19psi made 301whp friday on the dyno. cel came on and is showing code 35. obd1. i have looked all around and can not find such a code. some one help me. also i have already tried changing ecu's still shows same code
no such thing as code 35. you must be reading it wrong.
30 is automatic transmission so that doesn't make sense. code 5 is MAP. pull the code again.
I've been in this game for 7+ years it's code 35 that's the only reason I'm reaching out to you all, I'm stumpt. 3 long flashes and 5 short. The closest code to that is 36 which I know is only hem ECU equips with traction controll. I've tried to use a diff ECU but same code. Anyone else?
Code 35 actually DOES exist with Chrome. It means your tune is messed up. Get a new chip, burn a fresh tune to it, and make sure you seat it properly.
