rod bolts
i found this and checked them accoringly
7 13204-P72-003 BOLT, CONNECTING ROD torque OEM 33lbf/ft ARP bolts use strethch gauge, approx 50-55lbf/ft
found here https://honda-tech.com/forums/tech-misc-15/engine-bolt-sizes-bolt-torque-diagrams-2001-gsr-listed-2840082/
damm car developed a tapping sound today, and i wanted to check to ensure its not from the bottom end so i went through all the torque specs tonight and they were spot on.
i located the area but its between the block/tranny/head where they all meet lol so its a process of elimination for me i guess.
yah the oil was clean, and i just woke up out of my sleep saying damm valve so ill pull the head today
the last time i floated a valve i could turn the crank pully and feel it catching this time i dont
Yeah sounds right. My Ls OEM spec was like 23lbft I think and I tq my ARP rod bolts to around 26-30lbft, cant remember. Been driving the car like that for close to a year no issues.
sanman, hopefully the rest of the motor is okay, and you can get it back up and going again with minimal time/money
put the new studs in with the vice in my garage. then you put the cap on, use the moly lube and tq the nuts and rodcap down. loosen it up and remove the cap. do this 3 times total. then, with the rod cap on and torqued to spec, i brought the rods to my machine shop to be checked and honed to make sure there is no out of round on the big end. ive done this on 2 engines now never had a problem
