Abnormal Oil Consumption!
Old Mar 29, 2012 | 08:41 PM
DawgC2's Avatar
Default Abnormal Oil Consumption!
So here's the case. I already replace every suspicious spots with new oem gasket and new valve seal too. Cleaned up the engine bay to a point that i'm willing to lick it, refill new oil, drove it for a good couple days, then there are no trait of "leaks" at all. but the dipstick still read low somehow! I did a comp test and a leak down test the results are all good so that I excluded the possibility of bad bad piston rings. Any insight?? It's a waste of money to buy oil between 3000 miles regular period!
Old Mar 29, 2012 | 08:46 PM
el crapitan's Avatar
Default Re: Abnormal Oil Consumption!
pcv valve
check it
Old Mar 29, 2012 | 11:21 PM
TOO MUCH TORQUE's Avatar
^yes check the pcv valve.
There is a chance your piston rings can be stuck which wont allow the rings to move freely thus causing consumption. You can do a few things to loose these stuck rings
-mmo piston soak or some other piston cleaner
-auto rx
-in 2nd gear from about 3-4k rpms gun it to redline and let it engine break back down to about 5k and repeat 2-3x more times. this can potentially loosen all that carbon in your rings. I actually did this and after 4k miles on the oil change, i dumped the oil and cut opened the oil filter and found small bits of carbon in the filter element. I know it was carbon because i rubbed it against white paper and it powdered up like chalk does.
If your control rings are worn, only fix is a rebuild or new block. Hondas usually have a problem with their oil control rings...compression test wont tell you this, the dip stick does.
How much are you burning? my 01 ls with 130k miles burns about .5 quarts in 5-6k miles.
Old Mar 30, 2012 | 03:46 AM
yea, oil control rings is another possibility. are you actually burning oil though? you have blue smoke?
i'd check the pcv first, since it's easy enough to do.
at idle, pinch off the line between the intake manifold and pcv valve. if you don't hear the pcv valve click, replace it
Old Mar 30, 2012 | 11:08 PM
DawgC2's Avatar
Thx for all the replies Ima do these tomorow and come back with updates!
FireInTheHead
Nov 4, 2014 04:15 PM
sjt401
Dec 7, 2010 05:23 PM
lilshady6796
May 24, 2009 04:07 PM
IgnitionZ05
Apr 12, 2007 11:20 AM
crxtreme27
Aug 26, 2003 01:25 PM
