98 Civic CX HB Rear Defrost Bulb
Old Mar 29, 2012 | 01:39 PM
peteyb's Avatar
Default 98 Civic CX HB Rear Defrost Bulb
So I just replaced my climate control bulbs and guage cluster bulbs with blue incandescents. I should have pulled the cluster before hand to see how many bulbs I needed though, because everyone said that you need 1 #194 but my cluster (from a 96-00 EX) needs two.
So now I was going to order another #194 from autolumination and shipping is going to be $3.50 for one bulb. So I figured while Im at it I might as well get some more bulbs and decided to change out the rear defrost switch. Problem is I cant find what size bulbs I need anywhere on the net. Can anyone help me out and let me know what size these are?
Also, anyone have recomendations on what other bulbs I could change out, since I might as well get the most out of the shipping charge as I can?
Old Mar 29, 2012 | 02:08 PM
96_coupe's Avatar
Default Re: 98 Civic CX HB Rear Defrost Bulb
here is a good thread on interior lighting hope it helps
http://www.d-series.org/forums/diy-f...onversion.html
and you should do the dome light if you havn't yet
Old Mar 29, 2012 | 04:16 PM
motegicivic's Avatar
The rear defogger bulb has 2 bulbs and they are special from Honda with little foam boots on them.
Old Mar 29, 2012 | 05:54 PM
peteyb's Avatar
Thanks for the link 96 coupe. And Ive already swapped out the dome light with an led #194 that I happened to have on hand.
Thanks motegicivic, I was worried about that when I couldnt find out what kind of bulb it was. Oh well, might have to just live with it not being blue like the rest of my lights.
Old Mar 29, 2012 | 07:23 PM
96_coupe's Avatar
A trick that seemed to work for me was to cut a little square of aluminum foil and put it against the back of the case cutting slit for the bulb to fit through and a hole for the mounting screw helps disperse the LED light better. I got the brightest #194 bulb from superbrightleds.com and i can see EVERYTHING in my car at night haha
B16CRXT
Lighting
Oct 30, 2011 08:58 AM
ekhatchey
Honda S2000
Aug 18, 2010 06:09 AM
FW_EJ8
Jan 23, 2008 07:26 PM
cbmprelude
Jun 3, 2007 05:04 AM
95sivee
Dec 18, 2005 07:45 PM
