Honda S2000 Honda S2000
cluster bulbs?
Old May 1, 2010 | 03:06 PM
ekhatchey's Avatar
Default cluster bulbs?
i have a ap1 cluster in my hatch and i want to upgrade the stock bulbs to led bulbs not anything crazy like the qube engineering setup i just want a relacement type bulb but for it to be led's any one know where i can get the bulbs with the holder for the bulbs and what the size is so i can order them
thanks in advance
Old May 3, 2010 | 07:52 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: cluster bulbs?
What exactly do you wanna do, make the orange brighter? You cannot change the color by swapping out a few bulbs like on a civic...
Here is the qube setup:
You can buy an array of LED bulbs from here:
http://autolumination.com/74.htm
They are probably "Neo-Wedge" Type A, B, or C Cluster bulbs. To know which size exactly, pull out a bulb and measure the base of it. They have 8, 10 and 12mm sizes (AB&C)
Old Aug 14, 2010 | 04:50 PM
xero_xero's Avatar
did you get all of your gauges to work properly? i have been looking at this for the past year and the downfall for me is finding the vss signal converter and anything else that may need to be utilized for other signal inputs.
and if your willing, would you give a breakdown of this cluster? i have a few on the more common ones like prelude, civic, and integra.
Old Aug 17, 2010 | 04:32 PM
ekhatchey's Avatar
yeah every thing works the signal converter is a speed healer v4 you want the universal one cuz of the harness the unit is the same for all of them just different harness parts from http://www.healtech-electronics.com/ and the modifry ect module from http://modifry.com/products/ect/index.htm (remember that this is a 5volt item not a 12 volt you touch it to a 12v wire bam its fried) and get the one that suits you ap1 or ap2 cluster just make sure you do everything and take your time doing it im working on making a plug and play harness from a used cluster (ek) that i hacked up and will solider the wires to the board connector leads and then to the plugs for the ap1 i just need the plugs for the ap1 and re do my bezel out of sheet metal (maybe)
Old Aug 17, 2010 | 04:56 PM
xero_xero's Avatar
i saw a guy do a da with a hacked cluster. wondering how well it would work. i would wrather buy one that works and has everything (not that it would be plug ad play)
Old Aug 18, 2010 | 05:53 AM
ekhatchey's Avatar
no i hacked (litteraly chopped up) up the extra oem cluster for the female part of the connector so i could make a female plug ek side of the harness from the cluster what do you mean a DA with a hacked cluster like from another model or just hacked to show something else??
Old Aug 18, 2010 | 06:09 AM
xero_xero's Avatar
DA is a 90-93 integra.
allvtecyo
Aug 2, 2014 09:53 PM
FW_EJ8
Jan 23, 2008 07:26 PM
rasta420
Nov 21, 2002 09:56 AM
CivicDXR
15
Oct 16, 2002 01:30 AM
