DO I NEED AN ADJUSTABLE FPR??
Yes I've searched. Yes if I get one it will be AEM
So I have a turbo b18c5, it has a walbro 255, Delphi 525cc injectors,stock fuel rail. I'll be somewhere around 400hp
Now I read you need one on anything bigger then a 190lph pump to keep your pressure lower but I have a feeling my injectors are going to be pretty much maxed, so the psi might need to be higher anyways?
TIA
TIA
No, you need to take the car to a tuner. 525CC injectors should be able to flow enough to handle up to 450whp, and any competent tuner can set it all up to work correctly for you. Don't waste your money on an FPR.
Yes it will be getting tuned when I get the motor finished and running. Just wasnt sure if it was something that was needed for my setup with walbro 255 and stock fpr
I would get one. It keeps a linear fuel pressure curve 100% reliably which means no random funny business down the road. For 100$ now you could save your whole setup someday.
Ask your tuner. I've been running DSM 480's on my turbo setup, 255, and completely stock everything else with zero problems. I doubt you'll need one.
Currently, a hair under 230. I've been talking to my tuner about my current build-in-progress, and he agreed that I won't need an adjustable FPR for the 500WHP I'll be making on the street, or the 700 goal on my track tune.
Is it useful? Hell yes it is. Is it needed? No.
Your definitely gonna need bigger injectors or you are gonna have to crank up the fuel pressure for 500 whp. It's recomended to upgrade the fuel rail at that level. You'll be seeing over 100psi of fuel pressure with those injectors.
500hp x .60 B.S.F.C. = 300
4 inj. x .80 duty cycle = 3.2
300 / 3.2 = 94
94 x 10.50 = 987cc
300 / 3.2 = 94
94 x 10.50 = 987cc
I said around 400hp my injectors should be good might have to turn the psi some though depending on when I want to stop making more power, most likely like I said it will be once I hit 400 hp cuz it will be a dd. I'm not going to upgrade the fuel rail I'm just wondering if I'm going to need the fpr
Get one. Get 750cc injectors for room to grow. Better to have injectors that can take whatever your throw at it and not be anywhere near full duty. But i'd keep it to 300hp on the street. 350 max.
And my real goal is high 300s low 400s. I didn't put all this money into this build to only make 300hp
which we all know coulve been done stock.So again guys, I will need it for sure correct?
Thanks again for the response
500 crank hp x .15 = 75
500 - 75 = 425whp roughly
400 crank hp x .15 = 60
400 - 60 = 340whp roughly
300 crank hp x .15 = 45
300 - 45 = 255whp roughly
500 crank hp x .60 B.S.F.C. = 300
300 / 3.2 = 94
94 x 10.50 = 987cc
300 / 3.2 = 94
94 x 10.50 = 987cc
OEM fuel rail, FPR and lines are good for up 500whp with needing to upgrade. So the stock FPR will be fine no need to upgrade it.
ID 1000cc injectors for the win, all the injector you will need unless going to E85 or super crazy power.
43.5psi fuel pressure 1:1
fuel flow needed 1000cc/min
injector size 1000cc/min
160psi fuel pressure 1:1
injector size 525cc/min
Pistonhead
Jun 20, 2001 07:38 PM
but do I NEED it?
