DO I NEED AN ADJUSTABLE FPR??
Yes I've searched. Yes if I get one it will be AEM
So I have a turbo b18c5, it has a walbro 255, Delphi 525cc injectors,stock fuel rail. I'll be somewhere around 400hp Now I read you need one on anything bigger then a 190lph pump to keep your pressure lower but I have a feeling my injectors are going to be pretty much maxed, so the psi might need to be higher anyways? TIA |
Re: DO I NEED AN ADJUSTABLE FPR??
cant hurt
No, you need to take the car to a tuner. 525CC injectors should be able to flow enough to handle up to 450whp, and any competent tuner can set it all up to work correctly for you. Don't waste your money on an FPR.
Originally Posted by doood
(Post 47105221)
cant hurt
I know that:) but do I NEED it? |
Originally Posted by jbpnoman
(Post 47105225)
I would get one. It keeps a linear fuel pressure curve 100% reliably which means no random funny business down the road. For 100$ now you could save your whole setup someday.
Originally Posted by Dc4LsTeG
(Post 47105233)
Yes it will be getting tuned when I get the motor finished and running. Just wasnt sure if it was something that was needed for my setup with walbro 255 and stock fpr
(Post 47105391)
Ask your tuner. I've been running DSM 480's on my turbo setup, 255, and completely stock everything else with zero problems. I doubt you'll need one.
(Post 47105414)
how much power are you making?
Is it useful? Hell yes it is. Is it needed? No. |
Thanks guys
Your definitely gonna need bigger injectors or you are gonna have to crank up the fuel pressure for 500 whp. It's recomended to upgrade the fuel rail at that level. You'll be seeing over 100psi of fuel pressure with those injectors.
500hp x .60 B.S.F.C. = 300 4 inj. x .80 duty cycle = 3.2 300 / 3.2 = 94 94 x 10.50 = 987cc |
I said around 400hp my injectors should be good might have to turn the psi some though depending on when I want to stop making more power, most likely like I said it will be once I hit 400 hp cuz it will be a dd. I'm not going to upgrade the fuel rail I'm just wondering if I'm going to need the fpr
yes i would say you need it
Well 400hp equates to over 700cc and how are you going to increase the fuel pressure without a FPR?
Get one. Get 750cc injectors for room to grow. Better to have injectors that can take whatever your throw at it and not be anywhere near full duty. But i'd keep it to 300hp on the street. 350 max.
Originally Posted by JDM_teh_WIN!!
(Post 47107186)
Originally Posted by grumblemarc
(Post 47107190)
And my real goal is high 300s low 400s. I didn't put all this money into this build to only make 300hp:P which we all know coulve been done stock. So again guys, I will need it for sure correct? Thanks again for the response |
500 crank hp x .15 = 75
500 - 75 = 425whp roughly 400 crank hp x .15 = 60 400 - 60 = 340whp roughly 300 crank hp x .15 = 45 300 - 45 = 255whp roughly 500 crank hp x .60 B.S.F.C. = 300 4 inj. x .80 duty cycle = 3.2 300 / 3.2 = 94 94 x 10.50 = 987cc |
OEM fuel rail, FPR and lines are good for up 500whp with needing to upgrade. So the stock FPR will be fine no need to upgrade it.
ID 1000cc injectors for the win, all the injector you will need unless going to E85 or super crazy power. |
OEM fuel rail, FPR and lines are good for up 500whp with needing to upgrade. So the stock FPR will be fine no need to upgrade it. ID 1000cc injectors for the win, all the injector you will need unless going to E85 or super crazy power. 43.5psi fuel pressure 1:1 fuel flow needed 1000cc/min injector size 1000cc/min 160psi fuel pressure 1:1 fuel flow needed 1000cc/min injector size 525cc/min |
