Fuel pump wont turn on- No spark
i was just driving the crx and the motor turned off just out of no were no bumps wierd sounds nothing jsut died.. Ive replaced the main relay and the fuel pump does not come on.. I put a positive to the fuel pump and it comes on but now i got no spark either from the dizzy brand new dizzy...
What is causeing theese issues ive replaced the main relay and the fuel pump is not broken..
check out your ecu! I had a wire short out to my ecu and fried something in it same problems. Found the open wire cleaned and covered it popped in a new ecu problem was gone!
my .02¢
my .02¢
having kinda same problem with 98 civic DX with b16b..just got a new DW fuel pump & injectors with JRSC kit pulled it out to redo and clean it up a little.Well i went drop it back in and now my fuel pump doesn't kick on..and where is the relay located..under dash in fuse box or behind glove box
Were ure lights still coming on?
and i dont think it would be the ignition swtich because the car cranks or does that have nothing eeven to do with it...
http://www.autozone.com/autozone/par...er=190358_0_0_
is this wat ure referring too?
it its cranking with no fire To the spark plugs, it is your dizzy, new or not, they do take a **** alot, get a buddy and turn over the engine,pull the plug wire out a and put to a grounding area, if you have spark you will it pulsing, no pulse equals no fire...bad dizzy, or wire connection to the dizzy...
on the other hand if the engine dont even want to turn over ..ck the alt fuse in Ur fuse box, buddy of mine replaced everything with no luck, come to find out it was just a blown fuse!! lol
92hatchboi
11
Apr 24, 2007 07:59 AM
92DXinMIAMI
Jun 8, 2005 06:43 PM
