Classic Hondas All Pre-1988 Hondas.
so confused
Old Mar 27, 2012 | 06:47 PM
soccerboo's Avatar
Default so confused
my 90 civic hatchback wont start it runs when u put gas into the carb but wont stay running....ive changed so much in it and cant get it to send fuel through my injectors...what to do? new: alternator,starter,fuel pump/filter,batt,fuel press reg,injectors,timing belt, water pump, idler pulley, other belts, fuel pump relay, spark plugs and wires,distributor....
Old Mar 28, 2012 | 05:45 AM
kp's Avatar
kp
Default Re: so confused
Is your Civic carbureted or injected? It can't be both. Stop throwing parts at it.
Old Mar 28, 2012 | 03:42 PM
Stretch7's Avatar
Probably should post this in the correct section where more people can help you.
Old Mar 29, 2012 | 03:34 AM
E-AT_me's Avatar
you say "fuel pump relay".. but do you mean the main relay? up underneath the left hand side of the dash?
and that's not a "carb".. it's the throttle body.. your car is fuel injected. not carburated..
Old Mar 30, 2012 | 03:16 PM
icebox187's Avatar
yeh it's probably one of those old twin injected throttle bodies from the early 90's. I argued with a guy for 20 minutes because he swore that the motor was carburated. Sounds to me like your' injectors aren't firing. The problem could be narrowed down in a couple hours if you know how to troubleshoot with a multimeter, but im guessing (because all the parts you are throwing) that you don't. The only parts in the system should be the injectors, ecu, wiring, and the sensors in the distributor. The ignition switch can also fail from time to time, and the main relay (probably your problem) activates the fuel pump so that there is fuel available when your injectors fire.
Old Apr 2, 2012 | 02:12 AM
soccerboo's Avatar
It's a DPFI...and sorry but it was the main relay...I just dont know where to go from here...almost everything has been changed...
Old Apr 2, 2012 | 03:00 AM
soccerboo's Avatar
When we pour fuel into the throttle body it runs for a few...can someone help me diagnose it please...
Old Apr 5, 2012 | 11:01 PM
NW Classic Honda's Avatar
Dumb ****, this section is for pre-1988 Hondas.
kaychi
Mar 28, 2007 03:56 PM
solofthesouth
Apr 15, 2006 06:32 AM
spettinger
May 25, 2005 11:46 AM
Unjockable
34
Mar 3, 2004 07:38 AM
