Question reguarding turbo build. -ARP head/main studs
Old Mar 27, 2012 | 05:07 PM
jfral087's Avatar
Default Question reguarding turbo build. -ARP head/main studs
Hi guys.
Basically I am in the process right now of rebuilding my ls motor for turbo in the future. I am down to the last few things to buy before I can start assembling!!! I am shooting for 350 whp with my set up. Nothing to crazy for now.
Two questions:
1. Do I need to buy both ARP main studs AND headstuds?
2. What rebuild gasket kit is good for a total rebuild. I just need a kit that has the gaskets that I need. I do not want to buy off ebay unless you have a recommendation on that.
One set that I have found is this one:
http://www.autopartsway.com/PartList...ead_Gasket_Set
And there is another set similar containing the oil pan gasket and what I assume are the pump rings. Total for the two is a little over 200 bucks.
I have learned a lot off this forumn and for that I thank you. Any comments appreciated. Thanks
Old Mar 27, 2012 | 05:10 PM
rastaintegra's Avatar
Default Re: Question reguarding turbo build. -ARP head/main studs
yes u do need arp head studs now the gasket to me the best place to get if from is honda.
Old Mar 27, 2012 | 06:23 PM
DirtyDA9's Avatar
OEM head gasket is best. Get ARP head studs. DO NOT get ARP main's, not worth the machining involved to make them work.
Old Mar 27, 2012 | 07:07 PM
phaphon's Avatar
as stated above honda should have the gasket kits for the head and bottom end
Old Mar 27, 2012 | 07:21 PM
Slacker93eg's Avatar
10 Year Member
Not to hijack, but I used ARP main studs and the only modification I had to make was with the windage tray?
Old Mar 27, 2012 | 07:26 PM
phaphon's Avatar
i think its one of those things where sometimes when using arp mains you have to line hone cause sometimes it goes out of round im just guessing
Old Mar 27, 2012 | 08:45 PM
4tika4's Avatar
dont forget to re torque the head studs after 10 heat cycles
Old Mar 28, 2012 | 03:29 AM
jfral087's Avatar
Ok thanks guys. I was thinking that main studs were a for sure that I needed. What other brand do I get?? If it's only small modification that I need to do to use them then I will do that.
Old Mar 28, 2012 | 03:55 AM
rich7777's Avatar
Does your crank turn freely?
Old Mar 28, 2012 | 04:30 AM
twkdCD595's Avatar
+1 on this.
Old Mar 28, 2012 | 05:52 AM
10 Year Member
Yes sir
Old Mar 28, 2012 | 05:58 AM
rich7777's Avatar
Yes sir
What did you torque them down to?
Old Mar 28, 2012 | 12:29 PM
jfral087's Avatar
So if I don't get arp main studs should I get new oem ones from Honda?
Old Mar 28, 2012 | 12:33 PM
rich7777's Avatar
Yes
Old Mar 28, 2012 | 01:23 PM
phaphon's Avatar
i reused mines
Cap'N Chronic
Oct 16, 2011 06:47 AM
Dontoh
Oct 13, 2010 07:59 PM
got00rice
Nov 16, 2009 11:22 AM
b17 rolla
Jan 12, 2009 09:01 PM
rschoener
Aug 18, 2003 07:48 AM
